Question about ASUS (M2NGREEN) Motherboard
Front panel of my pc cabinet not working
My pc cabinet has a plugin in front & back for microphone &headphone.  the back side plugin works but the front one doesnt works. i have connected the wires of it also. do i have to install some software for it.
  • achu_mimi Dec 03, 2008
    i have d same pblm too... what to da...
  • Anonymous Dec 07, 2008
    i have a Logitech quickcam.with a mirophone headset included and i dont know how to plug it into my pc without unplugging my regular speakers
2 Suggested Answers
  • 147 Answers
SOURCE: my pc cabinet has a plugin in front & back for
you can choose in your audio program controller betwen rear and front. some times there are disabled by default. try there and you can resolve situation you are.
Posted on Apr 10, 2009
Front 4 usb ports and microphone and headphone jacks don't work but the rear usb and speaker jacks do work. I've had the computer new since 2009 and they have never worked.
it sounds to me like the wires from the front panel connectors are not connected to the motherboard inside the computer case, open the case up find the front connectors wires inside and find out if there are any connectors on the motherboard to plug them into.
the reason the rear ones work is because they are soldered directly to the motherboard.
good luck.
Jun 28, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
When I plugin my headphones The sound dosn't go to the headphones.
First, try plugging in different headphones. If those work, then your headphones are broken and you need to replace them.
If those don't work, then please check to make sure you're not plugging them into the microphone jack - you'll see two identical plugs, usually the headphone one is marked with a pair of headphones.
If you're plugging known working headphones into the correct port, then your computer must logically be the broken thing.
Dec 20, 2013 | Motorola Mobility S9 Headphones
Pc headphone volume driver
3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it or you might have to depending on your operating system
Click start Control Pannel
Click on Hardware and Sound
Click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
Feb 18, 2013 | HP/Compaq P4 System - WinXP Pro/Office...
Can't get the headphone sound working from the laptop
The Laptop has 3 Ports on the side- Pink,Green,Black
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
click on Hardware and Sound
click on Sound
select that!!
Hope this helps.
Dec 01, 2012 | Samsung Silver 13.3" Ultrabook...
I bought an intex headphone trendy it is not working with vista
i think u might have to activate the front panel 3.5 mm jack if u r plugging it in the front side of u r cabinet
it can be done from realtek driver s/w
Jul 13, 2011 | Computers & Internet
Sir, I am 58 yrs old having an interest in computers.I have Two Problems.I hope you will extent your help with your knowledge and expertize in solving the problems. 1. The front audio panel when fitted...
As per your information, there might be some problem with front panel microphone.
1(a). please check the internal cable for audio from motherboard to front panel. if possible change the internal cable.
1(b). If not avoid using the front panel and use the extention cables for extending from back points of speaker connection and microphone connection. just like usb extention cable you will find the audio/mike cable extentions can be found in local electronics shop. so that when ever you want you can connect speakers or headphone and also microphone.
2. For entering to BIOS, use either DEL key or F2 key when you power on the pc. In that you can see all the features. -
May be this helps to you.
Jun 17, 2011 | ASUS P7H55-M LX Motherboard
My pc cabinet has a plugin in front & back for microphone &headphone. the back side plugin works but the front one doesnt works. i have connected the wires of it also. do i have to install some software...
Apr 09, 2009 | ASUS (M2NGREEN) Motherboard
Ibm 8303-21g front audio pin configuration
Manual usually has diagrams and pin configuration for your system.
If you don't have the manual go to their web site and take a look.
Feb 06, 2009 | IBM Computers & Internet
Microphone
6720 doesnot have an onboard MIC.
Please plugin an external mic( typically the ones you use with headphones- ) and try.
Should work.
Cheers,
An example of the headphone + mic is
http://cgi.ebay.in/STEREO-SOUND-QUALITY-HEADPHONE-HB-575_W0QQitemZ370068749474QQihZ024QQcategoryZ11682QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Jul 13, 2008 | HP Compaq Presario V6000T Notebook
Headphone jack not working.
If you have a headphone jack at the front and the back, it may be a wire to the front panel is not connected properly on the Motherboard.
Aug 03, 2007 | RaidMax Samurai 908 Yellow Mid Tower ATX...
ASUS (M2NGREEN) Motherboard Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
