Question about Lexmark C912 Led Printer
Lexmark C912 LED Printer
Have a 900 RIP error. Had this error on a T-Series model which
represented a frimware error. Firmware download was unsuccessful.
Will I need to replace DC-Controller (engine board) again for this model?
Replace the rip baord if the firmware download failed ie flashing firmware eprom has fialed
Posted on Nov 03, 2008
I am getting a 900 firmware error notice
A 900 Firmware error means that something has corrupted the code on your printer.
The easiest way to fix this is to go to www.lexmark.com > Support > Downloads and download the latest firmware for your printer.
May 27, 2011 | Lexmark X204n 4-in-1 Laser Printer
Rip software code 900
Please contact the IBM Printer Technical Support for more exact information.
A 900 RIP error means that you have a down-level firmware build on the printer. Its a software bug that was more than likely fixed in later issues of code.
Normally all you have to do is download the newest firmware build and then follow the instructions to upgrade the printer.
Don
Nov 23, 2009 | IBM Infoprint 1612 Express Printer
Lexmark x422
900 RIP errors are errors in the Engine Code. There is an EC1 file available at: http://support.lexmark.com/perl/support/support.cgi.
Download and install the file by following the link on the above page, first error discription.
Don
Mar 08, 2009 | Lexmark X422 All-In-One Laser Printer
I have an x642e all in one and the following message has appeared on the screen - 900.00 service R.I.P Software what shall i do? what doe3s it mean?
what is the exact error message?
am not able to understand the exact message.
please tell us clear.
and when is this error message shown?
Aug 14, 2008 | Lexmark Office Equipment & Supplies
Error message on lexmark printer
900 Service RIP errors are usually a firmware failure. Upgrade to the latest firmware from Lexmark. This link is for the C52X network model:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Aug 07, 2008 | Lexmark C522n Laser Printer
Lexmark c912
980 error code is internal printer error. This is beyond users capability.
turn off the printer and check all cable connections.
turn on the printer, you need to call lexmark service, if the error return.
Jun 24, 2008 | Lexmark C912 Led Printer
C912 horizontal lines in print
change your magenta led it sounds like that may be faulty big job if not theat then its a new rip baord which is under the cover
Mar 12, 2008 | Lexmark C912 Led Printer
900 service error with lexmark printer
OK, a couple of things... Some earlier Lexmark units had code on both a RIP board (raster image
processor) and an engine board. In this case, the code would have to be reloaded into both
boards. Fortunately, this can be done even if the printer will not boot to a ready state. However, if
this has already been done sucessfuly, the problem may well not be the printer but rather something
in the data stream. To confirm this, remove any and all data cables and reboot the printer. If it comes ready and you can print all the internal pages including the network config pages, then it is likely the
problem is the data stream. One must be careful when the printer is controlled by a print server
because the end user may not have control over the print que. If a corrupt or printer incomprehensible
job is stuck in the que, the printer will go to a 900 condition as soon as the network interface
initializes. This will continue until the print que is cleared.
Hope this helps...
Sean.
Dec 13, 2007 | Lexmark Optra T620 Laser Printer
900.00 Service
When I have seen this error in the field, I have cured it by updating the firmware. Lexmark has a paper in their Knowledge Base on 900 errors:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:556:0:0&framed=&docid=ENUS22164&relevance=1
Go through the suggested steps to try to narrow the problem down.
But if it needs a firmware update:
http://support.lexmark.com/printerfirmware/
Use code: Isfap129 to download the package the C530dn.
Hope this helps!
Nov 29, 2007 | Lexmark C530dn Laser Printer
Printer Lexmark T630
The error message is normally caused by either plugging accessories into the rip controller board or the engine board. In some models the board may be conbined. Or invalid or illegal commands sent from the printer. Try upgrading the firmware first. If that does not work you you may have a bad board. Hope this helps Click on the link below and select your operating system http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:359:0:0
Sep 10, 2007 | Epson Stylus Photo 1280 InkJet Printer
Lexmark C912 Led Printer Logo
250 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
