Question about AEG 23 in. 6410KF-N Electric Cooktop
Aeg hob cannot turn on hob as all four ring controls are showing "L"
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Posted on Nov 06, 2008
Thank you thank you thank you to the Apprentice... the user manual for my 6410KFN hob gives the WRONG instructions to turn off the child lock!! The Apprentice has it CORRECT!! Legend!
Posted on Apr 25, 2009
Call a service engineer, circuit boad is causing problems
Posted on Sep 30, 2008
My 5 ring induction hob works fine but has stopped showing H or h. Is it possible to turn this feature off accidentally or is it a fault?
do not think there is any OFF switch for the HOT indicator .if it all works why even worry about it .
Aug 08, 2015 | Neff Cooktops
Hob displays letter L, on all four rings. Can you tell me why please?
Could be the support frame for the heating elements showing through the glass.
Oct 08, 2014 | Kenwood KHC600TC Cooktop
Turn hob on and only get letter L on each hob and will not turn on
child lock is activated , switch on hob press - and + button simultaneously hob will return to normal. if zeros dont appear try pressing and hold - key slightly before pressing +key hold both for a few secs.
Jun 23, 2010 | AEG 23 in. 6410KF-N Electric Cooktop
Hob says 'L' when turned on, tried solution but still not work
i called up AEG customer service, and they said: Press the '-' and bottom right '+' sign and this should take off the childlock. So it looks like there manual was correct. It seems like in some cases you need to do this, or the method suggested in the other post
Jun 25, 2009 | AEG 23 in. 6410KF-N Electric Cooktop
Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Jan 09, 2009 | Cooktops
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Hob not working
It is child lock.
Sep 16, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
AEG 23 in. 6410KF-N Electric Cooktop Logo
2,300 people viewed this question
Top AEG Cooktops Experts
Charles T Nevin
Charles T Nevin
 Andrew Henderson
Andrew Henderson
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
