Question about ASUS (M2NGREEN) Motherboard
My pc shows limited or no connectivity for net after every 2-3 hour
Whenever i use internet, after evry 2-3 hour my pc shows no connectivity to internet.but when i use another pc with same net connection the problem doesn't occurs. i have to refresh my connection all ovr again to connect to the net. pls solve my problem.
  • kilinskeo Nov 11, 2008
    i also have the same problem..limited or no conectivity,,i am using the on board lan...please help.....
  • 97 Answers
Ok its more than likely your network card that you have in the pc is it on board ethernet and or plug and play one
Posted on Oct 02, 2008
Why can't I connect to Netflix?
my wifes Netflix takes awhile sometimes when
net traffic is peaked.
this morning we could not open any site but 2 hours later it came back. techies musta been werking on the lines
Aug 28, 2017 | Internet Computers & Internet
Whenever i download the results says check if you are connected to the internet?
In other words, you're not connected to the internet, when you start downloading.
1) Support internet
Does your provider support internet
2) Data-limit
If your provider supports internet, you probably have a contract, which puts a limit at the max. amount of data you're allowed to download per month.
Remember: downloading is not just downloading software. The limit-counter is also active when you start browsing the internet. The homepages you visit is like "downloading" text and images. Watching online movies, yes, even advertorials, is also actually "downloading" data, which is included in the limit-counter of your provider.
Oct 14, 2013 | LG Rumor Reflex - Titan Gray boost...
I've a Nokia E63 mobile set with a BSNL connection.. Whenever I try connecting to the internet it shows a message "Packet Data:Packet Data connection not available" & I'm not being...
1 checked first the you have installed nokia pc suit and proper driver installed or not. 2 checked that you have done proper network setting in pc suit. 3 checked that you have sufficient balance in your mobile for connect internet. if you dont have balance in your mobile. then first recharge your mobile
Aug 20, 2011 | Computers & Internet
My internet will not connect. Says the strength is strong, but internet is still unable to connect. We are using the netbook by sylvania. We have the lynxis router and the internet is constantly...
Please check in the Network connection whether the Connection status shows Limited/Local only.
If in case the it shows Limited Only, then follow the steps:
1) Unistall Network Driver and restart then Reinstall the Network Driver.
2) Installed Updated Driver from the Manufacture Site. restart.
3) This should resolve the issue. If the connection status show Connected/ Internet. Then Configure the Wireless connection, by accessing the Router. Check the Router configuration and computer's configuration,.
Nov 25, 2010 | Sylvania G-Netbook
Hi I am using ASUS router rt-g32 . whenever I connect my inernet via ausu it is not working but through ADSL modem internet is working fine. please help.I have reinstall and instaleed software of ASUS...
My asus rtg32 wifi wireless router is not getting connected to net. It shows connected (router with laptop) but its not connecting to net. I am not able to openany site. I m using BSNL connection. It shows no internet access.\r\n
Please suggest me what to do, what procedure to follow. Mine is windows 7 , 32bit OS
thx
shubham
shubhamformeATgmail.com
Aug 14, 2010 | ASUS RTG32 Router
My Hp Laptop is unable to be connected to the internet
sound like u might need to find the drivers for the cable modem even tho it worked on another pc i would try this first
Mar 24, 2009 | HP Pavilion dv6000z Notebook
Limited or no connecctivity
right click icon in taskbar then wireless connection
a connection should show highlight and click connect
if no connection shows on left side of page click refresh list you may need to do this a few times when a connection shows high light click connect
Let me know if this has helped if not you can do a connection repair
you may also want to update driver in device manager
Jan 26, 2009 | Dell Latitude C640 Notebook
Linux operating system show me the low bandwidth
This sounds like your Net cards are limiting your Band or that in your linux boxes you have set a bandwidth limit somewhere.
-Rel
May 30, 2008 | Computers & Internet
Wireless Internet causes blue screen of death
-- "limited conn.."-- you should configure the internet connection in the router's software ie 192.168.2.1 or any other IP for the router, use ISP help desk for this (if it's free).
Blue screens have numbers and sometimes explanations, usually they pop up because of incompatible driver, chek router software(driver) compatibility.
explanation of blue screens are in the following link:
http://www.aumha.org/errors.htm
May 05, 2008 | Dell InspironTM 600m Notebook
Motorola SB5101
ya u should have a router instead of a modem because modem provide only one ip address>and there is no DHCP server in the switch or hub>so buy one router which has 4 ether net port and connect it directly to the modem and connect ur two pc's behind the router then both will get a seperate ip address from the router both will go online
the connection is
modem-->ether net cable to the inter net port on the router-->and two ether net cable from both pc's to the 1 and 2 ether net jack on the router reboot all the devices>and modem+router+pc's then it will work>rate me solved if its helps thx
Nov 14, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
ASUS (M2NGREEN) Motherboard Logo
83 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
