Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Vertical stripes on screen.
By ripley607 on Sep 29, 2008
Hi.
This Tv displays fine except for 2 vertical lines running down the right hand side of the screen. The lines are around 1 inch wide each and show a mirrored image of whatever is showing on the screen.
I've been searching for a service manual for this particular tv to try and get into the service menu but so far had no luck.
Any ideas please.
Comments:
Sep 29, 2008
- The Model is......
Fujitsu-Siemens Myrica PQ42-1 plasma.
Sep 29, 2008
- screen line & row module?
how much would it cost to buy & replace?
thanks.
Same Problem
Nov 12, 2008
-   Vertical stripes on screen.-   Guest
Nov 06, 2008
-   lines down the screen from one side to the to other. middle line is darker others thin and not as dark.-   Guest
Best Solution
posted on Sep 29, 2008
Helpful)
shinayo1
Rank: Wiz
Rating: 82%, 97 votes
well, change ur screen their is failure in your screen line & row moudle
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
Have a Toshiba 42h83 that has a blue and yellow "shadow", any suggestions?
Answer
tv will not power up properly.??? the light will go from red to green for a quick second then back... (More)
Answer
Panasonic H D Plasma TV Model TH-42PX60U. Screen has shrunk 4" on poth sides. Help!!
Answer
2 yr old Toshiba, LCD has lost the color red, everything is blue and green/brown/gold???
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
