Question about Sony Cyber-shot DSC-W80 Digital Camera
Opening and closing 3 times and then saying turn off and then back on
My camera just started doing this one day. Were you able to figure out how to fix this? Thanks
Phil
gatorpsu@hotmail.com
So 2 weeks ago my Sony DSC-W80 stopped working. Our friends dog ran into the camera (in my girlfriends hand) full speed. It started opening and closing a few times, and then giving the "turn the camera off and back on" message. I read about tapping around the lens, etc. None of this worked.
I took off the camera body and carefully examined the interior of the camera. Turning in on and watching closely, I discovered the problem. Looking at the camera from the front, I saw a slider on the top right side of the lens that appeared to be jammed. I then saw a spring that was attached to the slider and free on the other end. Apparently when the dog rammed the camera, the other mount for the spring broke off (they are very fragile). The purpose of the slider is to adjust the viewfinder based on the zoom range of the lens. I simply removed the slider which had jammed when the spring came loose. Camera works flawlessly now. The only issue is that the viewfinder doesn't zoom, but who uses the viewfinder anymore anyway? Oh, and I have a screw leftover. What project isn't complete without having extra parts when you are done?
Hope this can help someone else!
Posted on Oct 09, 2008
My TZ7 says that it has a system error (focus) and will not take pictures, view pictures or menu and the shutter will not close when turned off. Help!
Here's a fix I got from Panasonic, I figured I would post this since I haven't seen this anywhere on the web and this post was the highest hit on google
Based on the information that you have provided, we suggest that you perform the following operation:
1. Turn off the camera 2. While off, turn the zoom button fully to the left or right (hold for about 3-5 secs) 3. Release then turn the camera back on... At this point in time the lens should retract. If it does not, repeat the previous steps however, press the zoom to the opposite direction than you did the first time around. If this does not resolve the issue, we recommend the product be sent to our Customer Service Center.
This seems to work for me. The lens retracted back in place and my camera resumed working.
Aug 28, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
Turn the power off and on again
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Samsung L200 Digital Camera
I took it to a camera shop. It cannot be fixed.
Your guy probably figured that out too. He kept the line open for 2 hours before I finally closed the screen. I really don't think his 5 minutes should cost me 14.95.
Jul 28, 2008 | Cameras
Blackberry 8130 Curve Camera Troubleshooting
I had this problem and I've tried everything posted and nothing worked so I just started messing around with my phone and may have figured it out. Here's what I did.
NOTE: I AM NOT RESPOSIBLE FOR ANYTHING THAT HAPPENS AND YOU ARE SOLEY DOING THIS ON YOUR OWN AT YOUR OWN RESPOSIBLITY. Good Luck
1. Click the Menu Button
2. Scroll to Options Icon (the wrench) and click it
3. Click Advanced Options
4. Click Applications and wait for the Apps to load.
5. Scroll down and delete the apps that you dont need (see what I deleted)
6. I first deleted ICQ Messanger by scrolling over it and selecting the menu button then clicked delete, then clicked Yes and let it reboot
7. After it rebooted I clicked the Camera button on the side and it worked after I rebooted
8. Then I went back in and deleted Yahoo Messanger and let it reboot again. (This is up to you)
9. Last I deleted Windows Live Messenger and let reboot once again. (This is up to you)
I deleted these because I didnt use them anways. These were the only 3 apps that I deleted since I never used them. If you want, you could even delete Brick Breaker if you dont play it but I wouldnt delete any other Apps other than these.
Jul 01, 2008 | Cell Phones
Lens cover error
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Jun 17, 2008 | Nikon Coolpix S1 Digital Camera
When i turn on my camera it says Turn the power off and on again
Hey, my camera the dsc- w80 did the same thing. When I turned it on, the lens opened 3-4 times and then it said "turn the power off and on again".
When the lens opened an closed, I pulled on it with my fingers and twisted it. I kept doing that: Turned the camera on and off, kept pulling and twisting the lens and now my camera works again!
May 15, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Not able to shoot photos
OK, I have this camera and it started doing this to me about a week ago.  I assumed it had reached the end of it's life after many, many excellent photos.  As a last resort when the lens popped out after first switch on (when it's doing the clicking business) I grabbed the lens and wiggled it gently back and forth (as if zooming a conventional SLR).  It appears to have been fixed, remarkably!  I switched off and switched it back on and all seems OK.  (I'm not holding my breath and will probably keep looking for a new one but for the moment it's sorted out.)
Mar 17, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Will not accept any tape
i bought this camara from someone with the same problem for 5 bucks at a yard sale. an easy fix. 1. blow the dust out 2. charge the battery. 3. put the tape in and when it gos down into the case close the door and turn it on, run tape on ff then rr then turn camara to record. if it says to eject tape at any time, eject it and do it again. it worked for me.
Jan 11, 2007 | Canon ZR80 Mini DV Digital Camcorder
Cameras lense open, camera off, when turned on it bleeps and turns itself off
i have exactly the same problem with exactly the same camera. It happened to me once before but by 'fiddling' with it, it seemed to catch back in place and turn on again. but this time it wont work. seems like a design fauly from samsung?
Nov 08, 2006 | Samsung Digimax V800 Digital Camera
Battery charge
Put 2 batteries in flashlight and ran completely dead. Charged them in 1hr. 50min. Pulled plug per directions for first time charge and plugged back in. Light went out in about 10 - 15 min. Plugged in third time with same results. Is this normal. Haven't tried them in camera yet.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
55 people viewed this question
Top Sony Cameras Experts
Larry Spears
Larry Spears
Are you a Sony Camera Expert? Answer questions, earn points and help others
