Question about Denon AVR-1706 Receiver
No sourround sound
I have all the speakers hooked in properly and all of the components working but I can only hear sound out the front three speakers. My back surround speakers will play when in 5 channel stereo mode but no surround sound for movies or in the cinema setting. The TV and all components are hooked in through component cables. What can I do to fix this?
  • 75 Answers
Read your manual well and double check all your connections,make sure the remote is working, check the battery contacts in it too. If you haven't got a manual, obtain one.
Posted on Oct 02, 2009
Hello- I have my denon receiver connected to my tv with 2 front speaker,2 surround and center channel along with the sub. The problem is that when i play a blue ray, all my speakers produce sound including...
I need to know the quality of the speakers on the TV. Try unplugging it from the speakers on the TV and plug it into the souround sound speakers only and see if it plays differently. Double check your sourround sound and makes sure you did not reverse a wire.
DCBdigital.com
Feb 28, 2014 | Audio Players & Recorders
My sterio won't make no sound at all and I don't know why. I have a sub slash speaker hooked up to it and another big speaker hooked up to it and it still won't play no sound at all
Is it possible that you blew out the speakers? Or that they are not connected properly? Showing the front of the Stereo is not at all helpful to understanding your issue. Please give a view of the back of the Stereo so we can determine whether it is improper wiring, blown speaker, or faulty components.
Dec 08, 2012 | Audio Players & Recorders
I have a set of logitech X-530 speaker for my computer with windows home 7, i have had the front left and front right speaker working properly, however now i cannot get any sound from any of the...
Try to disconnect the input connector of your speaker and touch the input jack of the unit if you hear a hazing sound it means your speakers are working properly but if you don't hear any sound your speakers are bad. Open the speaker unit and check the amplifier section of your unit. If you don't see any burned electronic component inside. Check the wiring of your unit.
To check if the audio of your computer is working. Plug in the input a headset if you hear a sound while you playing a music in your computer it means the audio of your computer is working good.
Jul 12, 2011 | Logitech X-530 Computer Speakers
I have a pioneer vsx 818 v amp, when I set it up we get noise / beeps etc from the surround sound speakers but then when playing a film in 5.1 we get no sound from the surround speaks ..driving me nuts !...
To get sound out of your surround speakers, first off go through the receiver setup and make sure that is correct. Also, usually the best soundfields to use for sourround sound is PLII Movie or dolby digital. Next , make sure the source you are viewing is capable of outputting 5.1 sourround sound. Lastly, it is a good thing to remember that sourround speakers are only intended to reproduce sound effects. You certainly can override it so that all speakers play full range audio, but that is not the intention.
Good Luck
Jan 07, 2011 | Pioneer VSX-818V-K Receiver
No speaker sound
There sometimes are three connectors on a sound card that are similar. A speaker output, microphone input, and stereo headphone output.
Try all three, if you accidentally put it on the microphone input you won't get sound output of that one, so try another.
Also, check in the speaker control panel for the sound to be checked to mute or volume turned all the way down.
Aug 01, 2010 | Dell Dimension 8200 PC Desktop
We want to connect a SL-B5 to a sourround system and the sound its not coming out what should we do?
is your surround system has a phono input? because most of the turntable can only work with the unit that has a phono input, phono input has a a built-in pre-amp. so if you're only hooking your turntable to an ordinary input then this might be the case, you won't hear any sound or sometimes weak sound.
Jun 13, 2010 | Technics SL-1210 Turntable
5.1 speakers dont work right on sound blaster card
Most music does not put out sound from the rear speakers. Test it with a DVD, most of them use the rear speakers for some sound effects.
Feb 22, 2009 | Creative Labs Sound Blaster Live! 5.1...
No sound from my speakers
connect the speaker cord to the socket on the tower properly and check for the sound mute
Sep 26, 2008 | Audio Players & Recorders
Surround sound will not come on with the tv but will with the dvd player on
Check to see if your speakers hook up to your dvd player. If so then your your dvd is sourround only.
if not then your tv having a problem.
Aug 18, 2008 | Televison & Video
My speakers all work, but the subwoofer sound lowers when they are all working
Hi, pls don't get me wrong, but might it be that you are just hearing more of either the front or the rear since they operate on the frequencies our ears are attuned to with the sub just producing the low ones. Other than that, might it be also the placement of the speakers? The front and/or rear are placed relatively higher than that of a sub woofer hence closer to the level of your ears and therefore you can hear them more distinctly while the sub being lower, you probably feel it as well as hear it but not as loud. Since all of them are working albeit the sound level, I can think of no other explanation. If however this is not the case before and that this problem just recently came up, then may I suggest that you bring the set to a qualified service personnel since this involve checking out the individual amplifiers and their attendant electronic circuitry. If you are comfortable working down to component level, you would probably have to start with determining how many amps are inside the unit and diagnosing each one including the PSU. Far chance as it may be, there is a possibility that the PSU is not able to supply the current demands when all the amps/speakers are working. Hope this be of some help. Pls post again how things turn up. Regards.
Apr 25, 2007 | Labtec Arena 530 Computer Speakers
Denon AVR-1706 Receiver Logo
146 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
