For Every master Printer,
I have epson stylus R230 when i turn it on the ink led and paper led is
blinking ,i has to try clean head and every connector for
cartridge,try to cleaned waste ink pad make it clear like new one, try
to checked every cable connector and i have done to reset my
printer, but both of red led still blinking.
Maybe who someone can give solution for my printer, thank you very much.
i have a problem with EPSON R230, Service Error, I have Firmware Software to resett the EPROM Chip of the Printer, but i am unable to Resett, cos the printer & software interface are not communicating properly. and continusly showing message to restart the Printer & do it again. HELP !
My epson stylus photo R230 Printer problems always
two red light blinking
please help me
thank you
Try cleaning your waste pad, then clear counter...... i'm hydrowebb
For Every master Printer, I have epson stylus R230 when i turn it on the ink led and paper led is blinking ,i has to try clean head and every connector for cartridge,try to cleaned waste ink pad make it clear like new one, try to checked every cable connector and i have done to
Down load the free software SSC service utility in net
install and open the software.....after open in right side of the monitor
where the time shows......one printer mark is there that is the software....RIGHT CLICK the programme and select PROTECTION COUNTER AND RESET PROTECTION COUNTER.....RESTART THE PRINTER NOW UR PRINTER IS READY TO PRINT
You need to download ssc service utility then clear your waste pad count using it
Epson R230 ink & Paper Lamp Blinking problem
service require
when i give print command the printer will take the command and gives some error sounds and it wont print. give mw some suggesttions
Epson R230 ink & Paper Lamp Blinking problem, and notify you when a new solution is offered.
I have epson stylus R230 when i turn it on the ink led and paper led is blinking ,i has to try clean head and every connector for cartridge,try to cleaned waste ink pad make it clear like new one, try to checked every cable connector and i have done to reset my printer, but both of red led still blinking
