Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top
load models rely on an analog timer that controls the cycle used to wash
the clothes in the washing machine, rather than a digital control board
found in most front load models. The timer contains a number of moving
parts and is physically turned to choose the wash cycle. Because of the
high usage of the timer, it will eventually break, requiring
replacement. Rather than calling a service technician to repair the
timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the
timer. To unscrew, hold the dial with one hand and turn the knob
counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position.
5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
if the video doesn't play try to click how to replace timer to this URL:http://www.do-it-yourself-washing-machin...
please rate my answer to keep my account active...
Go to this link or copy then paste this url then rate my answer..any rating will much appreciated...
this is the link:http://www.fixya.com/marketplace/prothre...
