Question about Zanussi ZBF360 Electric Single Oven
Zanussi Built-In Oven Clock keeps resetting?
have a Zanussi ZBF-360 cooker and every so often the clock resets to 12:00. At this time, there is a buzzing sound as if it is on a timer. None of the timers are set and all read 0:00 (ecxept the clock).
Is this a short circuit?
  • 3 Answers
The 1000uF/10V condensator in the timer unit has to be replaced.
Posted on Dec 28, 2011
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
you have to push 2 of the buttons at the same time. usually - and + for 3 seconds. you will see the display change. good luck.
Jun 01, 2017 | Zanussi ZBF360 Electric Single Oven
Clock always resets when switch switched off and then need to reset it. is there any way of bypassing this clock. i done need it
no it is designed to stay switched on all the time by keep turning it off at the mains could damage your timer and then it wil not reset keep the main switch on all the time it will be ok the only time you switch off is for cleaning or a repair or you go on holiday
Sep 13, 2011 | Zanussi ZHQ575 Electric Double Oven
Trip swich went when turned back on no power in oven at all
Hi intial problem will probably be a faulty heating element locatated behind the panel at the back. the zbf260 has no clock but if its a zbf 360 set the clock before the oven will function. otherwise the fault has damaged another component on the oven. which can be in order of most likley.fuse if on 13a supply/ thermostat/ selectorswitch/ thermal cutout/jw
Feb 09, 2011 | Zanussi ZBF260 Electric Single Oven
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
Oven not working - rest of appliance fine
It is most likely that the oven heating element has failed and will need to be replaced.
This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
Jan 17, 2010 | Ovens
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Zanussi zbf 760
Gently but firmly pull one of the other buttons out and use that to reset it... you can buy new buttons on ebay
Oct 03, 2017 | Zanussi ZBF660 Electric Single Oven
Clock
Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
May 07, 2007 | Zanussi ZBF660 Electric Single Oven
Zanussi ZBF360 Electric Single Oven Logo
1,409 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
