Question about Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor
Minn kota problem
Motor suddenly quit.. Batteries are at full charge.. Indicator lights show know power.. Is there a fuse in the motor somewhere that could be blown.. The motor is about two years old.. I have had to replace the foot petal already... Thanks for any help!! jim
  • 1 more comment
  • Anonymous Mar 01, 2009
    asdfasfasf
  • Anonymous Mar 08, 2009
    same deal with mine I did notice the onboard minn kota charger is reading check connections which I did found nothing wrong still?
  • Anonymous Apr 25, 2009
    I havae a 70lb Maxxum bow mount. When I try to use it at high speeds it just quits as well. This time it hasnt come back on like it did before, due to possible over heating, i guess. Checked everything, all looks good. Talked to Minn Kota, they said that the "board" in the foot pedal might be fried?????
    Problem Solver:
  • 11 Answers
Same deal with mine, was using it with no problems until I turned up the trust alittle and it just quit, never turned back on nor did the circuit breaker pop. Talked to Minn Kota thy said the board might be fried as well. So took it to a authorized dealer. I had 2 issues (only minor with the motor) Easy fix for mine was under the button on the foot pedal is a small round magnet about half the size of a pencil in diameter or so. The tech said it got recessed down to far and if it should happen again just pull it up again. So took it back home re-installed and no luck, just heard a tiny ticking noise from the foot pedal, no prop movement. SO I checked the batteeries, all good. Even though the connectons had very minor corrosion I decided to disconnect all and clean them. Re-connected them and now I am back in business. Dont understand it, but hey it works until I actually test it out on the lake. Hope it helped
Posted on May 01, 2009
  • BB31 May 01, 2009
    Also I asked the tech , he said to check your breaker, if it is 30-35 amp, upgrade to 50 amp, but most boats already come equipped with 50.
    Scholar:
  • 157 Answers
Hello Jim. You have lost your power some where. Start with the wire & terminal connections to the battery. Open the bottom of the foot pedal and check the wiring connections there. Note be very careful here for you have the battery still connected. You may have a fuse in line some where blown. You can check for voltage with a VOM(volt meter) on the wire terminals. Good Luck.
Posted on Oct 02, 2008
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
    Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
    Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Hello, I have a Minn Kota 440 4 Bank Charger. I recently heard it spark when I plugged into my 115V AC power source. Since then I have no charging light indicator and no actual charging occuring. I tried...
    Hello Brad / Colee
    The voltage converter in the charger has gone out (violently). Do not use this charger in your craft anymore. There is no longer any kind of guarantee of isolation, and galvanic corrosion may be accelerated if the boat is sitting in the water and you try to charge batteries.
    Replace the charger. Your craft and your lives aren't worth the risk. You can try contacting Minn Kota to see if there might be some kind of warranty assistance.
    Aug 29, 2010 | Garmin Minn Kota MK 440 On-Board Charger...
    I have a Minnkota Riptide 80# thrust trollmotor.I have power to the head but motor will not run. It is a bow mount with twist grip control.When I mash on the power indicator button ,it lights up showing I...
    1. possibly a broken connection to the motor where the propeller is located. 2. Also could be a bad motor. 3. Look for a fuse location for a possible blown fuse to the motor. 4. motor brushes could be the problem.
    Nov 23, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
    Burning out fuses on trolling motor at battery
    not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
    Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Minn Kota 55 directional problem? (night fisher)
    Hi!
    Here is a schematic:
    Max 55
    There is no LIGHTED directional indicator, but there should be an indicator nonetheless on top.
    Best of luck!
    Mike
    Jul 07, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    I need Minn Kota Power Drive operators Manual
    I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
    Jun 09, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota Maxxum Trolling Motor
    I had the same problems with my 70lb, my motor just quit while on the lake, took it to a minn kota service repair shop. I had two issues. One was the little magnet under the button on the foot pedal got recessed to far down, the tech told me if it happened again pop the button off and pull the magnet up some. Simple fix. I took it home put it back on the boat and nothing just a slight ticking noise heard from the pedal with no prop movement. So I thought maybe somethin was wrong with one of my batteries. Unhooked everything, tested both of them, all good. Even though there was hardly any corrosion, I clean everything, hooked it up and "WALLA"! Power! Problem solved, for now. Waitng to test again out on the lake
    Aug 24, 2008 | Minn Kota Maxxum 70 Universal Motor/Sonar...
    Minn kota turbo35 electric motor only stays on full spped for 10 minutes.
    I dont know how old your battery is but they will sometimes show full charge but not last long cause of age. Try a differant battery.
    Jul 26, 2008 | Boating
    Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
    1,726 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
