Laptop powers up but display even on external screen
  • lfloppy Oct 05, 2008
    hi i ve put ram in another laptop and it works fine and put the other ram in the xo5 still same not brightness either adjusted,im thinking it,s processor or graphics.processor can not be change as it attached to mainboard.
    Genius:
  • 1,250 Answers
Change the RAM
Posted on Sep 29, 2008
My toshiba satellite l645 wont display at power on even when i connect the external VGA and press the function Key and f5 no display. no beep codes even when the RAM is removed and the caps light beep once...
hi
to test if the lcd screen is faulty or if its the inverter
plug in another monitor to the external monitor plug
when you turn on the laptop if the 2nd monitor displays the desktop your lcd needs to be replaced
if the 2nd monitor is also black your inverter needs to be replaced
common problem
Aries
Oct 19, 2013 | Computers & Internet
Dell laptop not detecting external display
Usually the external monitor and laptop screen toggles in one of three states.
LCD only
External monitor only
Both LCD and external monitor
Wait a couple of seconds between when you press Fn F8
This model laptop may not allow ectended display.
May 29, 2012 | Dell Latitude D830 Laptop Computer PC...
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
NO VGA DISPLAY TOSHIBA SATELLITE M300 FOR VISTA
Hi What precisely do you mean by VGA display, is your laptop not displaying anything on lcd screen,or its having problem giving display on an external monitor connected via a vga port.
if there is no display on the laptop LCD screen, then turn the laptop on and observe for beeps sounds and hard disk spinning sound if still no display is available plug the laptop to external monitor and again restart the laptop. if there is no display on the external screen and laptop is displaying well in LCD, Then most probably you need to press some keyboard combination on laptop keyboard eg: Fn + f4 , refer to your laptop manual also.
Mar 21, 2011 | Computers & Internet
My compaq presario v3000 note book is not booting even power is comming bt only with black screen. nothing on display
Hi Friend, In this case I would recommend you to please connect the external monitor to the laptop and check if you get the display on the external one or not
If yes, it means the LCD has some issues with the LCD cable
If nothing on the external as well, it indicates that the system video card or motherboard has some issue
Dec 10, 2010 | Computers & Internet
Periodically the screen is captured by horizontal lines completely across the screen. Cannot access programs or even shut down properly. Any suggestions. Presario 700 laptop using Windows Vista. Thanks
This issue is due to the malfunctioning of the screen or due to any other internal hardware malfunctioning of the notebook.
To further isolate the issue, I request you to connect the external monitor and check.
Once after connecting the external monitor, please tsp Fn+F3 Switch between the display and external monitor in the following order:
Display
External monitor
Display and external monitor
If the external display is fine then the issue either could be due the malfunctioning of the display cable connector between the screen of the notebook and motherboard or due to the malfunctioning of the screen.
As this the hardware issue, Please contact the nearest repair center to get it resolved.
May 29, 2010 | Compaq Presario 700 470024-192 Notebook
Connect broken laptop screen to external monitor
Suggestion- on my toshiba fn-f5 switches display modes, but to remove display connectors, you may have messed up your keyboard ribbon cable connection. it probably has a small sliding lock to hold it in place- if the lock isn't tight, your keyboard may not be recognized, which could mess up your display. Also, make sure your battery is charged and/or your power supply to your laptop is connected. hope this helps!
mothmanmeg@gmail.com
Sep 06, 2009 | HP Pavilion dv6000z Notebook
My screen doent dispaly at start-up.
Try connecting and external display screen to your laptop's external display port. If the external display is working, then try to access your laptop display connector (usually can access by removing the top power button access cover and/or the keyboard assembly) to the motherboard and disconnect and reconnect to motherboard. Power laptop back on, if still doesn't work, then could be the display invertor pcb or the actual display. If you have to order a display, make sure the display invertor board comes with it. Hope this helps, Ed.
Aug 25, 2009 | Dell Latitude D820 Notebook
Acer Aspire 5050 screen is blank
Hi, if it works with an external monitor it's more likely an LCD problem. When you push the power button, noting comes up on the main LCD screen? not even the Acer logo etc.?
Did you set your video card to use an external monitor and disabled the primary LCD? If so, you need to go to display settings, advanced and go to ATI Display and make sure that the notebook monitor is on.
Apr 02, 2009 | Acer Aspire 5050 5430 Laptop
Blank screen on start up on Acer Extensa 4620
Did you switch displays to the external video? Try hitting the Fn key and whichever function key at the top of the keyboard has a little TV screen icon over it at the same time.
Jan 04, 2009 | Acer Extensa 4620 Notebook
Computers & Internet Logo
David Payne
David Payne
