Question about Black & Decker String Trimmer Cordless 12" 18V
B&D 18V cordless grasshog: Autofeed won't stop
The autofeed feature on my B&D 18V cordless grasshog works a bit too well: the line feeds out constantly, whether it needs to or not. I've looked at all of the places on the unit I can get to easily and nothing looks broken. The white lever under the cord spool is okay.
  • 1 more comment
  • wmsampson Jan 28, 2009
    Thanks, but I replaced the spool and it still happens.
  • Anonymous May 02, 2009
    I have the same problem. The autofeed on my cordless grasshog will not stop releasing the string. And the white lever looks OK. What can I do?
    I have the same problem. The autofeed will now stop releasing the string when I use my cordelss grasshog. The white lever looks OK and I still have plenty of string on the spool. Help!
  • 313 Answers
SOURCE: My grasshog gh600 wont feed
check out a white plastic lever at the back of the spool line. if its broken then replace it. cost of the parts around $4.00 or so. this parts controls the auto feed of the spool
Posted on Jun 26, 2008
  • 4 Answers
SOURCE: 18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
Posted on Aug 07, 2008
SOURCE: auto feed spool doesn't work
10 to 1 yours is doing what mine is, line comes out all over... I think there is a little spocket on the center shaft under the spool... When I replaced line I lost this part and know one shows this as a part on there web sites... I don't know what to do??????
Posted on Oct 13, 2008
SOURCE: Line gets tangled in gear under feed spool
Problem solved. We noticed something was broken off a small part inside the spool holder. My husband took it to the local hardware store, and one of the employees gave him the part from a trimmer that had been returned.
Posted on Apr 07, 2009
  • 16 Answers
SOURCE: I need directions to replace string on black and
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Posted on Jul 07, 2009
Epson tm u220b manual feed works, autofeed does not work
Probably the rubber sheet pick up "fingers" have hardened over time and are unable to grip it. This is a common autofeed problem.
Nov 03, 2016 | Epson Office Equipment & Supplies
How to I feed the line in my Black and Decker battery GrassHog weed eater
There are 2 models one has a extendable handle these are both Grasshogs, if i was told incorrectly please contact me. Thank you
12" 18V Cordless Trimmer and Edger MODEL # NST2118 Page 10,NST2118.pdf
18V Cordless Trimmer and Edger MODEL # NST2018,NST2018.pdf
Jul 09, 2011 | Black & Decker Garden
Do you know if this screwgun will accept square head autofeed screws. Also can I use other bradnd screws than makita?
There is an accessory for a #2 square drive bit part number 784647-5 which you should be able to but at any store that sells Makita items. Also I would think (but am not certain) that any quality autofeed screws as long at the collation is the same should work.
May 03, 2011 | Makita BFR750 18-Volt LXT Lithium-Ion...
I have bleck and decker grass hog auto feed and it does not work
There is a smalll white part below the spool called a "lever". This is likely in need of replacement. Call Black and Decker at 800-544-6986 with your Model No, and Date Code (stamped on the trimmer itself near where the extension cord plugs in). If it is still under warranty they will send you the replacement part - if not, I loooked it up and it's less than $3 for the part itself.
May 25, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Vertical black line on side of copies only when using autofeed
Clean the small piece of glass on the flat bed. Should be on the left side of the flat bed when you lift the doc feeder.
Apr 11, 2009 | Canon Office Equipment & Supplies
Restring 14" electric weed trimmer? string keeps breaking
I just assume you used stronger line on an autofeed string trimmer.
Aug 17, 2008 | Black & Decker String Trimmer Cordless 12"...
Have Lexmark X7170 Have black line running on copy on left third only when using auto feed.
IF the line only appears on the autofeed, then the feeder optics have a dirt or some other contaminate on the optical sensor/lens area. A good cleaning inside the autofeed where the optics scan should resolve
Jul 05, 2008 | Lexmark Office Equipment & Supplies
Black and decker grasshog
check the white plastic lever location at the back of the spool. replace if broken. less than $3 part
Jun 13, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
300 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
