Question about Dell A920 InkJet Printer
Paper does not pull though
My printer has just not pull the paper though any more, it seems to be pulling it to the right, i have checked the paper guildes and they are ok.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dell Master
  • 1,362 Answers
Clean the tires w/ alcohol, they are probably slipping
Posted on Sep 29, 2008
My Epson R220 keeps pulling the paper in on the right side only, causing a jam. Any suggestions?
Once you place the papers in the tray, adjust the paper holding tray knobs present on either side if the tray such that it holds the paper kept in the tray firmly on both the sides. This will ensure that the paper is fed into the printer in a straight maner even though your printer pulls the paper only in the right side.
I hope this helps in solving your problem.
Thanks
Mar 14, 2010 | Epson Stylus Photo R220 InkJet Printer
PAPER PULLS FROM THE RIGHT ND THEN GETS STUCK...
These printer are made to be used offten. Did you put in new copy paper, the old paper made had curled or struck together and printers do not like that. I have a printer which "plastic paper guild" seems to be in the way and misalining the paper. I removed it.
Also I learned that not refilling the color ink made the contacts stop working, even after cleaning them. Keep trying.
Sep 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My Epson CX5800F is pulling the paper into the printer crooked
I had the same exact problem. Get a piece of fine grit sand paper run it though face up a coupe of times. It works!!! My printer now is great. A friend told me this because a printer repair person told her.
Jun 12, 2009 | Epson Stylus CX5800F All-In-One InkJet...
Misfeeds paper pulls to the right--says paper jam-no jam
there could be a paper jam or some paper still inside.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 17, 2009 | Lexmark X3350 All-In-One InkJet Printer
Paper feds but does not stay alligned. It crinkles paper and pulls it to the right.
something seems to be wrong with the rollers that pull the paper thru. probably one side pulls faster that the other or the other does not pull at all. I recomend you take the printer and get it repaired at the service.
Feb 22, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Printer won't pull paper into printer
How long have you owned the printer. How long have you had this problem? Is the paper old? Sometimes storage of the paper causes humidity and can cause this problem. You might want to try newer paper or clean the rollers with some alcohol on a rag/cloth. If you need any other assistance let me know. If you have a moment to accept and rate my solution I would greatly appreciate it.
Thanks,
Lee
Sep 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
OUT OF PAPER
The printer will attempt to pull in a sheet of paper out of the tray. If none is pulled, this is noted because a microswitch is not closed by the paper sheet as it goes by. This is the cause of the message. Check to be sure that the rubber roller that grips the paper initially is clean. I'll leave further comments to Benimur our local printer expert.
Dan
May 01, 2008 | HP Officejet Pro K5400 All-In-One InkJet...
PRINTER MP210
Problem seems to be in the design. The paper loading roller pulls on the corner of the sheet,cocking it to one side. If the paper was pulled in from the center of the sheet,it would be pulled in straight and evenly.
Apr 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
Print is not straight
It sounds like the paper is being pulled into the printer at a crooked angle. Check that the guides in the paper supply tray are adjusted correctly to the paper width and are tight against the stack of paper. Alternatively one of the rubber pinch rollers that pull the paper though is slipping or worn smooth. Regards
Sep 24, 2007 | HP DeskJet 930c InkJet Printer
Dell A920 InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
