Question about Krell Home Theater Standard 7.1 7.1-Channel Amplifier
Wiring Diagram required
Hi, I have a KRELL AVS Pre-Amp from circa 1999. Due to a problem I had cause to remove the fan to clean it. When switching on there was an extrmely loud buzzing noise and the fan won't work. I possibly put the wiring back wrongly but any comnmbination I have tried doesn't fix it. Does anyone have a wiring diagram for this?
  • SirSpendalot Nov 04, 2008
    Thanks, I phoned Krell in the USA and left a message. They called me back and said they had a printed Diagram but not one online that they could email. I didn't have a fax but they talked me through the wiring and I got it fixed and luckily no other apparent damage! It would still be handy to get a schematic though.
    There is no actual Model number, it was the First Surround Sound Pre-Amp from them I think called the AVS or Audio-Visual Standard Dark Grey Front with two half columns in Black at either side about an inch and a half in from the edge, left one with the Standby On/Off switch and the right one with a Massive Black Volume wheel in the centre of the rounded half column.
  • SirSpendalot Nov 07, 2008
    The ratings don't work properly as it won't allow me to mark solution 1 as Innapropriate and solution 2 as helpful!
Who has a diagram of marantz sr-73 mkii?pls give me a picture of that,thanks!
Posted on Oct 31, 2008
  • 4,234 Answers
At this point you may have fried the output stage. Is there a specific model listed on the back? I need that to locate the schematic.
Posted on Oct 10, 2008
How do I brigde a krell show case amp from 5 channels to three channels
Thai will require removal of the top cover to move jumpers or program dip switches in proper order. This will be explained in the owners manual which is located at Krells web site.
Steven Leckrone
The Service Department
30 Unquowa Hill St
Bridgeport CT 06604
Nov 14, 2014 | Krell Audio Players & Recorders
IBM x3400 server hanging / chipset & processor heating, but cooling fans are working properly.
Make sure that the fans are working at proper speed (not stuck or slow).
Secondly, heat sink could be clogged due to dust or not properly seated. Clean it if required. You may remove it, clean its fins and replace it back (for both processors if required) . Don't forget to apply THERMAL PASTE between the heat sink and the processor (If you remove the heat sink). The Thermal paste conduct the heat from the processor to heat sink which is then dissipated into air by the processor fan. You may also consider adding an additional fan, if required.
Also, place the PC at a well ventilated location so that the cool air enters it from the front and warm air leaves from the back.
Sep 26, 2011 | IBM x3400 Server
Hp proliant server is shutting down in every 4-5 hours due to cpu over hitting. its internernel health indicator on chassis is red & externel is Amber. One fan of one smps is not moving.
Heat up is mainly due the clogged heat sink and fan etc, which requires to be cleaned. It is strongly recommended that you clean the heat sink etc yourself or seek help from authorized professional at the earliest to avoid any damages to the PC.
If the system fan is not working properly, it may be due to dust inside the fan. This could be due to faulty fan or it may be stuck due to dust etc. In this case, using a compress air for cleaning would be helpful. This will result in heating up of the system and the processor/ graphic unit may burn. Try to clean the fan. You may use Compressed Air can to remove the dust etc. Cleaning and lubricating liquid available commercially can be used to smooth the inside rotating parts of the fa. Also, do check the fan power connection. Give it a try and try to make sure the fan is running. (if not it needs replacement). If you find it faulty, you may find and replace the fan by removing the old/ faulty fan by removing the 4 screws and installing the new one.
Also, make sure that the PC is placed in a well ventilated environment and the air flow the the PC is correct.
The procedure is very simple and I believe immediate action is required to prevent any damage to your machine and data.
Hope it helps! Good Luck!
Thanks for using Fixya!
Jul 29, 2011 | HP Compaq ProLiant ML350 G3 Server
When i make phono input..The Volume come very big.And all other input selecter volume come normal.
As long as the phono input is only being used for a record deck the most likely cause is a faulty magnetic cartridge pre-amp. If you are connecting any other device to these sockets, remove it and place it in another socket. If you haven't got enough sockets you can get a switching box to solve the problem. If you are getting the problem due to a record deck, make certain it hasn't got a built in pre-amp first, check the cartridge and wiring to it and all deck connections. If still no luck then you will find that you need to replace the pre-amp. It will be a single IC, which can be found by following the wiring from the phono sockets inside the amp.
Sep 14, 2010 | Technics SUV500 2-Channel Amplifier
Blown Fuse
Hello Kilwillie.
Anytime a fuse blows the circuit is being overloaded.
There are a couple of fuses that control your blower. The 30 amp fuse link and a 10 amp fuse for the blower motor relay.
If it is the 30 amp the blower system needs to be checked for the cause of the short.
Positive battery voltage goes to the blower motor and the control switch routes the ground circuit through a resistor to give various fan speeds.
Most common will be the blower motor itself having worn motor shaft bushings or an internal motor short. This will require motor replacement. Also have seen where a mouse has built a nest and it gets caught in the blower fan causing it to overlooad.
If the wire after the blower was shorting to ground the blower would come on high speed and not be your problem
And if the fuse is the 10 amp it appears the fault may lie in the blower motor relay. I believe that would be the only logical solution according to the wiring diagram.
Nov 30, 2009 | 2000 Hyundai Accent
On outside compressor for whole house AC: Critters ate wires. Have Blk & Red power in from breaker. 24vac switched from thermostat. 1 contactor with 24vac coil(original). 1 Capacitor w/ 3 terms...
There should be a wiring diagram on the back of the access panel. If you can't read it, check online for model wiring diagram. Don't guess, you may cause more expensive damage.
Jun 25, 2009 | Heating & Cooling
Krell 250a power amp
Hi There WLAW,
I am in Auckland NZ and do repair work for a high quality Amplifier chain so I could have a look at yours for you....
Being Local in Auckland it will save you sending it away off shore to Australia.
Cheers From YUBEUT (09) 357 7496
Dec 26, 2007 | Krell Home Theater Standard 7.1...
Krell Home Theater Standard 7.1 7.1-Channel Amplifier Logo
498 people viewed this question
Top Krell Audio Players & Recorders Experts
Are you a Krell Audio Player and Recorder Expert? Answer questions, earn points and help others
