Question about Air Tools & Compressors
LEAKING BOSTITCH AIR NAILER
THANKS FOR THE INITIAL SUGGESTION. THE MODEL IS N80SB-1
THANKS AGAIN, ED
    Guru:
  • 859 Answers
Your welcome. Todg, has a rude way about him, but he's pretty new and his numbers aint so great.
A lot of people forget to include a model number and we can only guess until we have it.
Are you still in need of help?
Worldvet
Posted on Sep 29, 2008
How do you change the rubber hand grip on a bostitch n80sb nailer? Do you simply stretch the rubber over the tail piece? Heat??
I haven't had to do this myself, but reference the link below for a guide to both parts and a diagram. This should help. You can also call as I have found them to be quite helpful.
Dan
Link: http://www.fixya.com/support/r5812776-bostitch_nailgun_dis_assembly_assembly
Nov 16, 2010 | Stanley Bostitch N80s Nailer -rebuild...
My N80SB framing nailer won't shoot the new nails (non-clipped head). What do I need to do?
For a visual on what type of nail you should use go here:
http://packagingandfastening.com/air_stick_nails_28_degree_framing.htm
You will find a list of differnet nails sold that will work on your gun. Bostitch is about the only nailer that uses a welded wire strip of nails. Good luck
Oct 25, 2010 | Stanley Bostitch N80sbn80n80c Nailer...
Owner manual
Most all manuals are available at www.bostitch.com, look for support tab, then select service parts and documents. Find your model number in the pull down list and finally select usage manual.pdf, enjoy.
Jun 18, 2010 | Stanley Bostitch Coil Framing Nailer
My N80SB nailer all at wonce started leaking air some where near the triger and wont work. Could you tell me what to do? Thanks Tommy
Most likely the "O" ring seal has given way for some reason. If your not experienced in repairing this type of equipment, considering how dangerous a misrepaired tool like this can be, I recommend taking it to a qualified repair tech. Double check your purchase date it may still be under warantee.
Jun 12, 2010 | Stanley Bostitch N80CB Coil Framing Nailer
Will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Jun 11, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
N80sb-1 stanley bostitch framing gun.
Yes your nailer will drive other sizes of nails. For info and parts go to www.bostitch.com and look for the support tab then select service parts. Here you will find parts list and manual. To remove the tva11 trigger valve remove the retainer pin (the pin is 3mm) for the trigger and remove trigger. Next remove roll pin/pins that retain trigger valve. Use heavy glove to catch trigger valve as you apply air pressure to gun. The valve could pop out with great force so try lowering the pressure to gun. Before installing the new valve, check the opening for sharp edges which will cut orings. Good Luck and email if you have more questions.
Mar 14, 2009 | Stanley Air Tools & Compressors
you probably have a trigger valve that is green. if so then it will have to be replaced, the valve runs about $ 20 but you can put it in your self.
Dec 26, 2008 | Air Tools & Compressors
try going to their website -I have several guns and each take at least 4 sizes of nails- yours should be no different- good luck hope this helps
Oct 11, 2008 | Stanley Bostitch N86S 1 Factory...
BOSTITCH AIR POWERED NAILER - AIR LEAK THRU TRIGGER
sounds like the rubber seals have dry rotted prob from not oiling it enough, but you should be able to go on the Bostitch web site and order new rubber seals for the gun
Sep 29, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
758 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
