HL-207ON Brother Printer
Paper is jammed ABOVE the feeder tray in the teeth that i can see when I open that tray.
  • elynn Sep 29, 2008
    do I unscrew it? From the front near the teeth?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Could not find that model????
I'm assuming you are talking about the fuser, where the paper exits? there are teeth or claws there that are supposed to help guide the paper out, when they get worn they catch the paper and make an accordion. depending on the model of the machine you will have to remove the fuser and take out the paper
Posted on Sep 29, 2008
  • CheckitRight
    CheckitRight Sep 29, 2008
    Yes, depending on the model you will see 2-4 screws and 1-2 wires, unplug 1st and let cool off. Not sure if you need to take any of the covers off, to remove the screws or fuser, but it should slide towards you to take out.
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
Cannot get at paper jammed in printer. How do I do this
You this manual to clear your paper jam.
Directly go to page No. 91 it explains how to open the door and paper tray to clear the paper jam.
http://static.globalcomputer.com/pdf/Brother-HL-2140-Mono-Laser-Printer-Manual.pdf
Regards
Rudra.
Oct 11, 2010 | Brother HL-2150N Laser Printer
THE PRINTER IS INDICATING A PAPER JAM, THERE IS NO SIGN OF PAPER, THE DRAWERS ARE ALL CLOSED TIGHT
Paper light flashing could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 05, 2010 | Brother HL-2040 Laser Printer
Got a paper jammed in my brother hl-2170w
Open the front cover of Printer, remove the drum and toner with force and put aside. Remove the jammed paper slowly so it doesnt rip. If you cannot find the jammed paper check in the back cover and paper tray.
Apr 03, 2010 | Brother HL-2170W Laser Printer
PRINT LABELS
You will need to use the manual feed slot which is above the paper tray.
The manual feed is meant for labels and envelopes
Dec 02, 2009 | Brother HL-5240 Laser Printer
Printer prints from manual feed but not from tray.
you need ot open up the papper tray and more the laser down then it should work
please rate my helf i need you to i am a exert
Apr 20, 2009 | Brother HL-2040 Laser Printer
Paper JAm
There are three places to clear the jam: 1. Paper tray (remove it and feel inside, clear paper. 2.Open the front (above the manual feed slot) inside is the drum - remove that and the toner cartridge, if necessary. 3. On the back - open the rear chute. You should be able to remove the paper in one of those areas. See the Brother web site for complete pictures ans instructions. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_006.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=4
Aug 20, 2007 | Brother HL-2040 Laser Printer
110 people viewed this question
jasbo
jasbo
