Question about Acer Aspire 5315 Notebook
Crashing, cpu?? computer will crash, usu when multitasking and the cpu running at max, have tried adjusting the dump file with no effect could this be a faulty cpu???
  • 49 Answers
Probably not. sounds like a power maneagement problem and overheating. do the normal maintenance like cleaning the cooling vents and such. you can find lots of other stuff aound the web about overheating problems with computers. the only thing that i have not seen on them is about the softwate power maneagement .causing the overheating problem. if this is the problem you have to reset the bios by power cycling. the configuration for the power maneagement in the bios is maintained by the small battety that also maintains other things like the clock when there is no power being supplied to the computer. removing this batttery and of course the main battery (since it is a laptop) will reset the bios to original specs. of course the clock will reset also....lol.
Posted on Sep 29, 2008
Plugin crashing
If you are playing games that use lots of graphics. You might not have enough computer ram installed running your computer over its limits placing to much strain on the cpu central processing unit causing memory dumps and crashes.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible. Hope this helps.
Dec 26, 2012 | Google Chrome
When i click on training it causes a crash dump
here are instruction to fix crash dumo to your sega football manager 2011
Step 1shock.gifpen up your steam
Step 2: Go onto your games list
Step 3: Right click on Football Manager and select properties
Step 4: Select the Local files tab on the far right
Step 5: Click the option Verify integrity of game cache
Step 6: Click the option Defragment game cache
It should now be complete
this worked for me
I'm sure there are other people out there who have had there game destroyed by Crash Dumps errors, sometimes screwing your save, sometimes even preventing you from starting new games forcing you to re-install only to come across the same problem later down the line.
So here is my 2 part guide to Crash Dumps, part 1 is how to set your game up to minimize the chances of your game ever getting this error, and part 2 is what to do to recover your save (If possible) and get your game back to a working state if you had this error already. Part 1 pretty much lists all issues that cause Crash Dumps and to set your self up to prevent it from happening.
Crash Dumps Prevention
There are certain things that increase your chances of getting an error, here is a list
1) FMRTE - Just dont go there, it screws your data base up beyond repair, you will not be able to get your corrupt save back if you have used this editor. Sometimes its been to known to cause damage to your windows registry too, unless SI make an official in game editor, using third party programs like this is all to risky stay away.
2) Size of Game - Even though I believe I have found the solutions to 99% of crash dump issues, it does not change the fact the game is not without major issues, the games coding causing endless memory leaks that lead to Crash Dumps errors.
So what I'm saying is try to go easy on your database size, either slow or at most medium size data base when starting a new game.
Also dont go crazy with the amount of leagues you select to be playable, if you have a good system 10 leagues at max.
If you must have lots of leagues and large data base I recommend you have at least 6GB of DDR2 or DDR3 ram, if you have an older system DDR ram will not cut it for crazy data base sizes.
3)Everything Up to Date ? - Make sure the following are up to date
+ Graphics Card Driver (Use manfactures site, sometimes windows will not find the most up to date driver)
+ Java - Make sure you have the latest Version
+Direct X - Latest Version your system is compatible with
4) General Settings in Game These are optional but I recommend you use these settings to prevent errors.
Uncheck the following boxes
+Use Skin Cache
+ Enable Data Collection (This is an important one, it will stop FM constantly building up the RAM useage and prevent Crash Dumps)
+ Play in Windowed Mode, Minimize, and Maximize Every Hour.
+ Disable sounds, and 3D cameras, the 3D sucks anyway text all the way.
+Play with Autosave weekly, 3 file rolling save for back ups, better safe than sorry.
+ Uncheck Threading, if you have a Dual Core processor, you do not need this to be checked, it takes away a complication. However if you have one processor with Threading technology keep it ticked, other wise the game performance will be poor.
5) Your Hardware Before Playing FM 2010 you need to be confident your hardware is all fully working, so you can rule that out if you need to trouble shoot in case you get the Crash Dump.
Consider and do the following before installing the game
+Power Supply - Is it at a high enough Voltage for my Graphics card ?, find out and upgrade power supply if need be, you should not be using a Graphics card if your power supply is under the recommended amount, your system will become very unstable, let alone Football Manager.
+Hard Drive Error Free, run Chkdsk, a windows tool to see if your hard drive has any errors.
To run chekdsk press the windows button and R, then in the run box type in CMD, the in the black command box type in chkdsk and press enter.
You should have a report of no errors, or windows will fix errors
+ Faulty RAM - This was the culprit for me, run a program called MEMTEST86, you need to download and Burn it to CD, restart your PC with the CD in the drive and let it scan.
If you are error free all good, if not note which RAM slot is reporting errors, remove or replace that RAM.http://www.memtest86.com/
+Dust Bunnies - Your system would be unstable in general if you have these, if it is a little unstable check the innards of your PC for obvious dust, blow to free dust from sensitive areas.
If you ever get Blue Screen errors while browsing, gaming, multi tasking, then Football Manager will certainly Crash Dump you ***.
Okay if you follow all these steps prior to installing your game you are very unlikely to get the crash dumps error again.
please rate me if this help you thanks...
Jun 05, 2011 | Sega Football Manager 2011
The Machine Reboots after displaying Blue Screen With Error Message
Windows is entirely in control of any blue screens; so the hardware spec is not relevant yet.
can you try reading your windows event log immediately after a crash? :::Start>all programs>administrative tools>event viewer
you are looking for an error mentioning a filename... C:\windows\~somepath~\Minidump.dmp
If you get yourself a copy of WinDB (here: http://msdn.microsoft.com/en-us/windows/hardware/gg463009)
You can then open WinDB and open/read that crash dump file (file open crash dump), and it will provide you with a filename of the driver that caused a problem (possibly even tell you what it was doing when it was called).. chances are it's one of the following causing the problem: Graphics Card drivers Storage controller drivers Motherboard drivers (Power Management related issue usually)
If you have the latest driver; then get the hardware checked out...
May 17, 2011 | Intel D865GBF Intel 865G Socket 478 ATX...
When I start my computer a blue screen pops up then it crashes. It has text on it but I don't get a chance to read it.
download Microsoft Debugging tool here
just select the version of your computer (OS and if it is 32bit or 64)
install it.
then check this link on how to use the windows debugging tool
click here
Every time that there is a blue screen error or a stop error, windows generates a dump file that has the details about the crash error. the dump file is located in this folder
C:\windows\minidump
you have to run the debugger, click on file, select ran deugger for crash error then after that browse to that folder and lod the minidump file.
in order for you to fully understand how to user the windows debugger, you have to read the link that i posted above.
the result of debugging will give you a detailed analysis on the problem, it could be driver issue, or the device or the OS itself
Sep 14, 2010 | HP Pavilion zd8000 Notebook
My desk top computer is always crashing and dumping, and receiving blue screen. I will I solve this? OS is Windows Vista Black Edition with processor Intel Pentium Dual CPU E2140 @ 1.60 Ghz.
It could be a number of things. First, have tried reinstalling vista and installing the latest drivers for your hardware? You also might have a bad piece of hardware causing windows to crash. I would start by backing up all your files, downloading and saving all the latest drivers and doing a complete refromat and reinstall of vista. If you are unaware on how to do this, then I recommend taking the pc to a good repair place and having them do it for you.
Aug 07, 2009 | Computers & Internet
System crash after upgraing memory for acer aspire 4315
If u have 2 ram in 1 computer memoryh frequence
conflict betwwen each other if both r differ.
So cheange yhour ram and check both rammeoroy frequence are same .
Mar 26, 2009 | Acer Aspire 4315 Notebook
When i am trying to use c++ on my system it is giving me message the NTVDM cpu has encountered an illegal operation
Here is an explanation of what NTVDM is: The NT Virtual DOS Machine (a.k.a WOW, or Windows on Windows), is a Win16 subsystem that runs under Windows NT, which allows 16-bit applications to run as if they were being executed on a DOS machine, with that machine's multitasking and segmented memory model. Because the system is multitasked 16-bit DOS and Windows applications cannot crash NT. However, 16-bit apps within a Win16 subsystem run the exact same way as they do on a DOS/Win 3.x machine; therefore, 16-bit apps within the subsystem can crash one another, or the subsystem. To prevent this, you can launch multiple WOW subsystems as long as your program does not communicate using shared memory. Windows NT will not allow NTVDM to execute instructions that try to directly manipulate hardware or memory locations. As a result, some DOS and Windows 3.x applications (such as games) may not run under Windows NT.
Feb 02, 2009 | Computers & Internet
CPU problem??
Hi benladen Your cpu is not the problem it is you dump file that gets overloaded with all the cache memory
Rigth click on my computer select properties, Go to advance settings and select startup and recovery setting make the write debugging information to small memory dump this works for XP and Vista. Next go to performance then advance tab and to change set the page file initial to 2000 and max 4000 this will give you programs more space to work. Remmember to apply ans set all setting before exit
Sep 24, 2008 | Acer Aspire 5315 Notebook
Blue-screen crashes
i suspect the cpu and or fan is defective
Jan 09, 2008 | HP Pavilion dv1000 Notebook
Acer Aspire 5315 Notebook Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
