Philips rear projection 55pp8620 colour fading
Purchase new lamps
Posted on Sep 30, 2008
Size of phillips 55pp8620 There is no picture and
Good day!!!!
I need to know first if your TV is on standby mode (red LED lit) or not?..If the green light lit your TV your high voltage (HV) is switch but you have open line on heater that cause of no picture and the sounds is chirping because of analog(antenna)/digital connection or bad audio chips..
I need this information above for specific diagnosis and to prevent more damage and failure..Also I need this information to avoid mistakes to buy a parts with no help...
also I need the model # because on my tread there are 2 model # which are correct? is it 60PP9202 60" or 55PP8620?..for specific diagnosis and for possible get a diagram..
Thank you very much for choosing my service!!!!
Rossiel Gomez (nineng)
Jan 20, 2012 | Philips 60PP9202 60" Rear Projection...
When I turn it on the screen stays blank and there
this a defective power supply, normaly the HV circuit is burned, needs to be repaired. send to repair shop
Jan 29, 2010 | Philips Magnavox 9P6034C 60" Rear...
Hi i won a 55pp8620 philips th eremote is not working and i have the letter F in the top right hand corner
It means the unit is in factory mode... Press both Volume Down and Channel Down on the TV itself until F is gone. Takes about 5 seconds.
Bill
Dec 21, 2008 | Philips 60PP9202 60" Rear Projection...
Colour misalignment and focus
You need a new convergence board. Not an easy fix, sorry.
Nov 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Philips Rear Projection Model 55PP8620 - convergence problem
Manufactures sometimes contract with other tv companies to build their tv. Regardless of the internal hardware you still have a philips tv. I beleive this set was made by Hitachi. And what you are looking for is a replacement board. This board is referred to as the small signal module. When contacting a rebuilt board, have the model# and the chassis# available. And contact PTSELECTRONICS.com or Andrews Electronics.com. The board you seek is in the rear lefthand side on the floor of the TV. You will see a pair of tall aluminum fins. Theses are the heatsinks for the convergence ICs. I would definitely replace this small signal module, as repair on the local level will require pulling the board in and out of the tv several times. The company will give a part number and then you may order this. Striving for success the first time!!!!
Sep 13, 2008 | Philips (867093110009) Projector Lamp for...
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
May 21, 2008 | Philips 60PP9202 60" Rear Projection...
PHILIPS 55PP8620
Good Day;
It sounds like the CRT COOLANT needs replacement, it is a fluid that trys too keep the picture tubes cool , but it some times get "dirty". The fluid is called 'PROJECTION TV COOLANT', it contains; High Concentration of Ethylene Glycol. You can purchase at M.A.T. Electronics; (215) 354-7667, in PA. Part Number 212072-16.
BUY at least 2 containers. CAUTION: remove tubes from TV, just alot of plugs,remove plugs, clean "fluid" chamber, replced discarted fluid. Good Luck, big IRISH. PS more INFO; come back.
Mar 28, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
