Question about Canon CanoScan 8400F Flatbed Scanner
B&w negatives. When i go to advance mode and select source, it says Platen. I can't get to negative film. How can I get to negative film mode?
  • karylgrimes Nov 14, 2008
    I cant get anything but "platen" either. Does anyone have a customer service number for Canon?
  • Anonymous Nov 22, 2008
    cannot scan negatives. there is no option in advanced mode
Try 1-757-413-2848
Posted on Nov 26, 2008
Unable to set CanoScan 8400F for color slides. The protective sheet has been removed from the document cover, and the slide film guide installed. Photo Studio Acquire panel Source selection has only...
kindly let me know your operating system so that i can give you precise solution. By the way you should go with the review for which I am providing a link below. If this does not solves ur problem kindly let me know alongwith ur operating system.
http://www.pcreview.co.uk/forums/canoscan-8400f-settings-35mm-negatives-4-x6-photos-t2637157.html
Jul 01, 2011 | Canon Office Equipment & Supplies
Scanner is scanning everything in with inverted colours, is this a setting somewhere in the ToolBox It was working but I think one of the settings may have been changed. Thanks
It seems that the Source is improperly set in the ScanGear software interface. From the ScanGear screen (where you Preview and Scan your documents/film), click on the tab labeled 'Advanced Mode' at the top. Under 'Input Settings', in the box next to 'Select Source', choose the type of film you are scanning (usually Color Negative Film if you are scanning 35mm negatives).
Feb 10, 2010 | Canon CanoScan 4400f MultiFunction Color...
Negative or positive option is not available on drop down menu on select source on ScanGear CS so how do I scan film? I am trying to scan 35mm film on my Canon 5200 F scanner using ScanGear. The manual...
I just had the same problem, turned out my FAU cable was not properly connected. Ensure that the cable is all the way inserted at the back of your printer, and connect the device to your computer. I hope this will work for you too:)
Jun 24, 2009 | Canon 5200F Flatbed Scanner
I am tring to scan my 35mm negatives
Select scan. When the window pops up look in the upper right hand corner of the window. You will see select source: drop down menu give you choices which includes negative film. Just select it. Then drop negatives into holder. Oh, make sure you remove the cover sheet that slides in and out of the cover.
Mar 19, 2009 | Canon CanoScan 5000F Flatbed Scanner
Option for scanning film doesn't appear in my source box
I was able to contact Canon via e-mail about the problem and they acutally responded! :)
Apparently all you have to do is disconnect and reconnect the scanner from the lid. Apparently, because the lid has its own scanning hardware and if your lid and scanner have become disconnected, the software won't give you the negative/positive options. Anyway, did the disconnect and connect thing and it worked!
Good luck
Feb 18, 2009 | Canon CanoScan 5000F Flatbed Scanner
Lide80 Film Scanner
You can scan all the image and then crop out necessary parts!
Oct 01, 2008 | Office Equipment & Supplies
Scanning neg
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Jan 22, 2008 | Epson Perfection 3200 Photo Flatbed...
Scanner incorrectly reads frame position on film
Yes there is
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Unable to use film adaptor
1) In the program you are working from, begin the scanning process. If working in full auto mode, as the scan begins you will see a message that reads TO CANCEL SCANNING IN FULL AUTO MODE AND SWITCH TO MANUAL MODE, CLICK CANCEL. At this point, click CANCEL, then MANUAL MODE.
2) You will now see all Epson Twain settings displayed. If the scanner has not previewed automatically, click the full page preview button (icon of a paper with one corner folded down).
3) Ensure the settings on the right hand side of the Twain are correct. For example, the DOCUMENT SOURCE for transparencies must be either TPU: COLOR NEGATIVE FILM, TPU: MONOCHROME NEG or TPU: POSITIVE FILM.
FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes. (If you are scanning a black and white slide in true colors, choose TPU: POSITIVE FILM as the DOCUMENT SOURCE and BLACK AND WHITE PHOTO as the IMAGE TYPE.)
If the DOCUMENT SOURCE is flatbed, the scanner will not activate the backlight in the transparency unit. If the DOCUMENT SOURCE is greyed out and you cannot select a TPU option, close the twain, reseat the power/communication cable connecting flatbed to TPU, then re-open the twain and try again.
4) Ensure the other twain settings are correct for the type of scan you are doing.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no guidelines on this; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing an AUTOMATIC THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, click the CONFIGURATION button and uncheck AUTOMATIC THUMBNAIL PREVIEW FOR FILM, then OK, and try the PREVIEW button (page with corner folded down) again.
In this mode, you will have to manually marquee or crop the slides you wish to scan. Use the left mouse button to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process (manually crop then scan) for as many slides or filmstrips are on the bed.
Aug 16, 2007 | Epson Perfection 1200 Photo Flatbed...
My scanner doesn't scan negative
" I can only select platen as the sourc. the film setting has vanished" - I had the same problem. Unplugged the USB cable from a shared usb 2.0 hub and plugged into an old USB 1.1 dedicated port and it started working. No ideas why (perhaps in the hub it couldn't detect the scanner model correctly)
Aug 12, 2007 | Canon CanoScan D1250U2F Flatbed Scanner
Canon CanoScan 8400F Flatbed Scanner Logo
154 people viewed this question
old marine
old marine
