Question about Zebra 110XiIIIplus Direct Thermal/Thermal Transfer Printer Motherboard
Zebra 110XiIIIplus printer
Printer lable feed is sporadic prints 1 2 3 or sometimes 4 then gets off line.its never the same and there is no pattern.
Turn the Printer off and turn it back on. See if it skips a couple of labels. If it does not the printer needs to be calibrated.
Press the Setup/Exit Key and the press the Next Key until you see Media Power UP: IT should say Calibration if it don't then use the arrow keys to get to Calibrate press the Next key again and you will see Head Close select Calibration using the same method mentioned above. After that Press the Setup/Exit Key and Save Changes Permanent. Turn the printer off and on again and the first 2 labels should skip while the printer aligns the media.
Test Print and see if that fixes the problem. Good Luck
Posted on Dec 16, 2009
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
Feeding-problems
you need to calibrate. hold the feed button down intill it flashes 4 times in a row and the quickly let go. it will feed some labels to calibrate and should stop at the tear off. you also have to set label size in the driver to keep from losing calibration.
May 14, 2010 | Zebra TLP 3844-Z Thermal Label Printer
I have 2 Zebra 110XiIIIPLUS printers ribbon out
Make absolute sure that the ribbons are following the path that printed in white on the frame. From there, do a ribbon and media calibration from the LCD display. this will calibrate the media and ribbon sensors and should solve your problem. Another method is to use the ribbon sensor and ribbon LED values from working 110xiIIIPLUS. Do this by printing a configuration label on your working printer and compare these to the values for Ribbon LED and Ribbon Sensor on your non-working printers. You can manually enter these values in the LCD menu and save settings. If all of this fails, you may have a hardware problem with the sensors.
Jan 28, 2010 | Zebra 110XiIIIplus Direct Thermal/Thermal...
I have a Zebra 110 XiIII p it does print different size bar codes
Keeping up with the Drivers is a very good idea, it will fix little problems that come along from time to time. Try resetting the printer defaults by entering the menu system and exiting, at piont of exit don't save permanently but cycle around to load defaults and exit. Go back in and set the printer up again, this time exit saving permanently.
Jan 21, 2010 | Zebra 110XiIIIPlus Label Printer
Zebra TLP 2844 printing landscape instead of portrait.
To change from "page mode" (protrait) to "line mode" (landscape) you need to complete the following steps.
1. turn the power off
2. hold the feed button down
3. turn power on, the feed button should blink, release the button.
4. when the feed button blinks green, press and hold until it turns red or amber. release the button.
5. turn the power off.
6. hold down the feed button and turn power on, the button should blink and release. it will now print a calibration page. 4 blanks followerd by 2 text pages, the last saying "Now in DUMP" press feed to exit. on the first print, the 4th line down will say either page mode or line mode.
Nov 04, 2009 | Zebra TLP 2844 Label Printer
We have a LP2844 printer that prints multiple blank labels sporadically. How do we stop it?
Make sure the label size is set correctly and the printer is calibrated. If this doesn't work download drivers from Nice Lable or Seagul Scientific websites to suit you Printer, these are more adjustable than the original Zebra drivers and handle small labels better.
Oct 15, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Prints 30 pages of junk instead of a Dazzle mailing
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default.
Jul 23, 2009 | Zebra LP 2844 Thermal Printer
Zebra 110xi plus not printer strainght across label
* do full manual calibration
* reduce the print speed & try
* set back feed as before instead of default
* try with little big labes
Jul 28, 2008 | Zebra 110Xi III Plus Thermal Printer
Will not print on all four lables, and does not print in the same place each time.
for starters you need to calibrate your printer.
Note: If printing in Direct Thermal Mode, default the printer first (4 flashes).
1. Load the labels and ribbon (if used) and close the printer
2. Turn on the printer power.
3. Allow the printer to feed or error out.
4. Press and hold the feed button until the green status LED flashes once, then twice. Release the feed button.
6. The printer will set the media sensor for the label backing being used and then automatically feed until a label is positioned at the printhead.
7. A profile of the media sensor settings (similar to the example in Figure 1) will print. Upon completion, the printer will save the new settings in memory and the printer is ready for normal operation.
8. Press the feed button. One entire blank label will feed. If this does not happen, try defaulting (Hold the FEED button until it flashes 4 times)
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 110XiIIIplus Direct Thermal/Thermal Transfer Printer Motherboard Logo
138 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
