Question about Lexmark Refurbished MARKNET X2000 SERIES PRINT SERVER(46D0000) (4034321) Print Server
Lexmark marknnet x2000 wont allow printing
I have just purchased this device and have rest the IP address.
Configuring the device through the print centre on an Intel Mac with 10.5.5.
All lights flash one after the other when trying to print. Eventually only the printing light is flashing but no printing is done. The message in the print centre is 'unable to connect to IPP host. Operation timed out
2 Suggested Answers
  • 37 Answers
SOURCE: Old IP address
You can reset the MarkNet X2000 to factory defaults - which includes resetting the IP address to 0.0.0.0 like this:
1. Press and hold the Test button until all four lights stay lit simultaneously, then release the Test button.
2. When #3 and #4 lights light simultaneously, press and release #1 (the Menu button).
3. When #3 lights press and release #1 (the Menu button).
4. At this point the X2000 print server has been restored to the factory default settings and should have an IP address of 0.0.0.0.
-John
Posted on Feb 06, 2008
Where is the IP address located on my Lexmark s515 printer
Printing a network setup page
A network setup page lists the configuration settings of the printer, including the IP address and MAC address of the printer.
  1. Load plain paper.
  2. From the printer control panel, navigate to: button_home_0.jpg > Setup > button_select_0.jpg > Network Setup > button_select_0.jpg > Print Network Setup Page > button_select_0.jpg
Nov 30, 2013 | Lexmark Office Equipment & Supplies
Where is the ip address on the lexmark
You can locate the printer IP address by viewing the printer network setup page. See the User's Guide on the software installation CD for more information on printing a network setup page.
Nov 30, 2013 | Lexmark International Lexmark S515...
How can I print a configuration page from the E260dn Lexmark?
Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, then print a network setup page and locate the IP address
in the TCP/IP section.
Click Reports.
The following reports may be viewed from the Embedded Web Server:
Reports
Device Statistics
Device Settings
Device Information
Profiles List
Printer Server Setup Page
Jul 25, 2012 | Lexmark E260dn Laser Printer
4300 laserjet wont print docs. IP address is same as a network computer, cannot change IP address? Configuration page prints and I check ports etc but will not print. cannot change IP address. Help....
Have you tried changing the IP address from within the driver's properties? Go into the print driver properties, and under the Ports tab, edit the 4300's port and change the IP address that it is associated with. You may need to reboot the printer once you make the change and save it, but that should allow you to change its IP address.
Jun 13, 2011 | HP LaserJet 4300 Printer
How do i set the ip address for e250dn
Follow these steps: 1. Press the "Operator Panel" button to print a Network Setup page.
2. Locate the entry labeled "UAA" or "Physcal Address."
3. Write down the 12-digit address. An example is "00:1A:2B:3C:4D:5E."
Set the IP Address 1. Insert your Lexmark drivers CD and select "View Documentation."
2. Select "Software and Utilites" and click "IP Setup Utility" to start the program.
3. Enter the physical address for the printer in the "Discover Print Servers" field and click "Discover."
4. Select the printer from the "Configure Print Servers" list and click "TCP/IP Settings."
5. Click "Suggest Address" if you'd like the utility to locate an available IP for you, or enter the IP of your choice in the "IP Address" field and click "OK.
May 22, 2011 | Lexmark E250dn Laser Printer
Hi - in my three-computer, PC network environment, I just changed from a static IP to a dynamic IP situation, and can't use some of the printers. I think it's because my DP 300U print server is stuck on...
Shut down all the printers and computers.
Boot all the printers first to establishe their IP addresses.
Then turn on a computer and search the network group for what is online. All the printers should show as long as they have theit IP address.
Once their static IP is established the rest shall follow with what ever IP addresses are left. A dynamic IP setup grabs the available ip address and can conflict with a device that has that static IP if the static IP device is powered up after.
Aug 25, 2010 | D-Link DP 303 (DP-303) Print Server
How do i set up my wireless canon printer to my laptop? I keep getting messages saying can't find the printer.
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 21, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Lexmark X644e All-In-One has link light, but does not print or ping.
If you have a router or wireless router, these routers assign a standard class C network address ie. 198.168.0.xxx or 192.168.1.xxx behind the real IP address issued by your ISP.
The reason why you cannot ping the print server could be that your computer and print server have different IP address ranges. Eg. the IP address on both the print server and the computer must contain the same first three group of numbers, only the last numbers are different.
Try configure the print server's IP address again.
Feb 12, 2010 | Lexmark X642e All-In-One Laser Printer
I need to change the IP address on my hp color laser jet 2840 coud you help me with that
Most HP printers can be reset to factory defaults (or cold-reset ) by turning the printer off and holding down the Online or Go button while turning the printer back on. The printer control panel display should read "Cold Reset" or "Restoring Factory Settings" or something like these lines. This will remove any IP address that the printer had previously.
When you plug it in, your router should have assigned an ip address automatically. Go into your router and look at the attached devices and it will show you what ip address has been assigned to each device on your network.
Use Web Interface or Manually Assign an IP address NOTE: Network HP Printers allow you to manage them via Internet Explorer. You can enter the IP address that the printer currently has and access its configuration settings. This assumes that the web interface hasn't been locked.
NOTE: We recommend that you install the latest version of Sun's Java software before trying these steps. See this How To: How to Update Sun's Java 2 Runtime Environment Plug-in.
  1. Print the Configuration page if needed. You will be entering the "current" IP Address.
  2. Open Internet Explorer. Delete EVERYTHING from the Address line.
  3. Enter the IP Address in the Address line and press Enter.
  4. You should then connect to the printer. If this fail, go to the next section to assign the IP address manually.
    NOTE: There are 2 basics versions of the web interface. Type 1 is on newer printers. Type 2 is on older models
  5. Type 1: Click the Networking tab.
    Type 2: Click the Administration button. Click the Configuration tab.
  6. Edit the IP address, Subnet Mask, and Gateway as needed.
  7. Do not change any other fields.
  8. Scroll to the bottom and click Apply. Click OK.
  9. Close Internet Explorer.
  10. Restart the Printer. Print the Configuration page to see if number was set.
NOTE: If the above steps do not allow you to assign the IP address via the Wizard, you will need to do it through at the printer itself.
  1. Go to this HP Support Page.
    Configuring TCP/IP through the Front Control Panel
  2. Click the link to your printer model. Highlight these steps.
  3. From the File menu choose Print. In the Page Range section, click Selection. Click Print.
    Note: For the complete printer user guide, go to the HP Printers Support & Troubleshooting page. Locate your specific printer type and model. On its home page, under self-help resources, click the manuals link. Download the printer's User Guide (not the Getting Started Guide). Look for steps to manually configure TCP/IP parameters from the printer control panel.
  4. Follow the steps from the printout to assign the desired IP Address to the printer.
    IP address will be entered at the IP BYTE prompt
    Subnet mask is entered at SM BYTE prompt
    Gateway address is entered at GW BYTE prompt
    Note: The syslog server IP address (LG BYTE 1=) and timeout (TIMEOUT=) do not need configured.
  5. Once the IP Address is entered, restart the Printer. Print the Configuration page to see if number was set.
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | HP LaserJet 2840 Printer
Old IP address
-John
Feb 06, 2008 | Lexmark Refurbished MARKNET X2000 SERIES...
Computers & Internet Logo
240 people viewed this question
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Robert Monigold
Robert Monigold
micky dee
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
