My coffee pot worked great until yesterday morning when i pushed the "ON" button to start my coffee. It blew a fuse on the curcuit board. I tried several times, but it continued to happen.
This sounds like a short in the main heating element. If you are within your 3 year warranty, Phone Bunn and talk to their warranty department. They will give you a RMA number and give you further instructions. If not, there are no replacement parts available for these brewers.
The top burner on our bunn coffee maker is getting to hot, causing the coffee to pop, do you have...
(More)
The top burner on our bunn coffee maker is getting to hot, causing the coffee to pop, do you have any suggestions on how to fix this problem? Please advise
I have a small water leak at the back of the coffee pot. Water is coming from inside the coffee pot....
(More)
I have a small water leak at the back of the coffee pot. Water is coming from inside the coffee pot. Is there a gasket or part that has gone bad that needs to be replaced.
my bunn coffee pot is leeaking water out the holding pot, then it onloy makes half a pot of coffee...
(More)
my bunn coffee pot is leeaking water out the holding pot, then it onloy makes half a pot of coffee even when a full pot of water is poured in to start the process-what can we do
