Question about Lands Phones
Nikkai VoIP funky internet phone - software problem?
I also have a problem with Nikkai Funky USB VoIP Internet Phone. After installing i get this comunicate : List Index out of bounds (1). And it comes with houndreds of small windows which keep appearing on my screen until i press Ctrl+Alt+Del and end program. No idea what is wrong. Please help.
I have windows Vista, not Xp.
Thank you
  • 2 more comments
  • Anonymous Nov 23, 2008
    I have the same problem with a US Robotics USB Internet Phone.
  • neil-2 Jan 08, 2009
    Same problem with a U.S. Robotics phone. No ideas what to do.
    I successfully installed the same phone on two other computers (desktop).
    The problem occurred on a laptop.
  • Anonymous Mar 08, 2009
    Im not sure where to check for sounds speaker etc, ive looked in options on skype and computer and it doesnt give me the option? I have the us robotics skype phone and when plugged in it doesnt work and comes up with an error message index out of bounds 1
  • Anonymous May 04, 2009
    This work around does not fix the problem.
    errors keep on comming, even when all sound setting are set back to computer default devices.
I installed a U.S. Robotics VoIP phone on a Vista Laptop and had exactly the same problem.
The reason why it happens is because a VoIP phone contains a microphone and speaker. Windows Vista/XP senses the microphone and speaker as two seperate entities. It then sets them both as the default microphone and speaker. You won't notice this being done until you get the 'Index out of bounds (1)' error.
Simply go to the control panel, and look for the sound/speaker/audio device option, then the sound and audio devices, click on the audio tab and make sure the 'sound playback' and 'sound recording' default devices are that of the laptop/pc and not of the VoIP phone.
Hopefully that should solve the problem.
Dan
Posted on Feb 18, 2009
  • scott_bootma
    scott_bootma Oct 08, 2012
    I have the exact same problem and the solution above does not help....any more ideas?
  • scott_bootma
    I have the same problem and the solution above does not help....any more ideas????
I have an account how can i set it up on this computer
Check the Internet is live by logging on to the magicjack website.
VoIP Phone Service Internet Home Phone Service Providers magicJack
Then plug a telephone into the magicjack device.
Then plug the magicjack device in to the USB port. It should then log on to the internet and download any required software.
If you have the internet, but magicjack was not able to get through contact Customer support through the website.
International VoIP Phone Service Customer Care Support magicJack
Apr 04, 2013 | magicjack.com
Help me in recording phone call in VoIP, any help would be greatly appreciated....
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} hi
you can find this dialog software for your VoIP phone call recording purpose. Dialog voip software is purely software based system which uses latest technology called port mirroring which makes the software less costly. For details visit website Voice Call Recording Software
Aug 31, 2010 | Computers & Internet
How to do internet settings manually on nokia e71
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: 5551231234@sip3.voipvoip.com ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:5551231234@sip3.voipvoip.com )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
Jul 07, 2010 | Nokia E71 Smartphone
Nikkai driver
Hi there and welcome here
I did find this driver : Nikai Dv7000 Driver:
http://drivers.91srv.com/Nikai-Dv7000-Driver.html
You have to give me the phone model number if you need another driver
Hope it helps
IF not, then try to return here
Have a nice time over there
About where the product is coming from, I did try to search on the internet and did find only this information :
http://www.designworldonline.com/articles/183/228/NKK-Nikkais-Best-New-Performer.aspx
http://www.applegate.co.uk/who-sells-who/nikkai-1000677.htm
http://www.nkk.com/
Please rate my answer
Jan 08, 2010 | Lands Phones
Have system for voip. Only can't hook up the
Try getting a router that has one in/4 out between modem n voip. Your voip unit should have an RJ45 connector to connect to router, not your computer. The USB connector might be to connect the voip to a different type of router, and will not be used. The 2 phone connectors are for two different phone lines that your voip provider can provide you with.
Sep 20, 2009 | Toshiba DOCSIS Cable PCX2600 (DAZ8823A-R)...
I was on the internet on my archos 5 and it froze
Mine gets into a funky state some times. Try to do a cold power reset. remove the battery, wait 10 secs, put it back in, put power into from the USB cable then try to power it up.
Aug 26, 2009 | Archos Internet Media Tablet MP3 Player
Cannot connect using LG internet cube software
I had the same problem but now i have found the solution for it. Its not the software its the phone. Go to your Phone Settings hit Connectivity and then Usb Connection select Data Service and now connect your phone to the pc and select connect in Mobilesync and it should work. After you are done using MOBILE SYNC you can simple go in settings once again and choose mass storage for any downloads!!!
Dec 17, 2007 | Computers & Internet
Vista home basic
You probbably have to login with a user that has administrator rights and then run the same program again.
Nov 16, 2007 | Microsoft Windows Vista Ultimate Edition
Lands Phones Logo
987 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
