Question about Sony Ericsson K700i Cellular Phone
Signal problem my problem is my cellphone unit when i bring it in the city proper the unit can pick up the signal, if i bring the unit out side the city proper no signal with estimated radius from the city of 2 kilometers. thanks
  • 64 Answers
Good day
this may be an issue with your mobile service provider. ask for the coverage of their cel site.
however, with the k700i's internal antenna design, its capacity to get signal is minimal sa compared to its external antenna cousins. however, with the rise of the trendy cellphones, manufacturers tend to design theor phones with internal antenna, hence, i guess, we have no option but to live with it.
Posted on Oct 09, 2008
Locked out of cellphone cant remember e-mail or password
Have you tried reinstalling the battery after some delay to bring the phone to stand by mode before changing the code for locking ?Connect to computer with proper PC suite and interfacing cable to change the code in the lock file.Take to moble repair shop to reset the proper jumpers to deactvate and erase the set password of the lock application.
Feb 19, 2012 | Samsung Cell Phones
I have a 2010 Oliver City CPI, motor scooter. The engine wont start. The starter seems to work and theres gas in it. Tried the kickstarter and wont start. bad spark plug maybe?
My problem started like this,I found No spark so changed coil,cdi,voltage reg,eventualy found stator at fault,check pick up strip on flywheel and pick up pin on black pick up coil,this is fixed to stator and sends spark signal to cdi,mine were both rusty/dirty,I fitted a new stator,but now have light problems..stator seems to be to strong.
Jul 14, 2011 | 2011 Cpi Oliver City
Hi i want to ask what is the password of GTA vice city for cellphone? thank you
There is no password for a "cellphone". The game will have people call you, you can't call them.
May 18, 2011 | Rockstar Games Grand Theft Auto III & Vice...
My cordless phone is not functioning properly.I get consistent disturbance in the background while talking on cordless.Please help me remove this noise.
This can be due to poor meshing of the base and handset , a poor signal strength that tends to pick up stray EMI signals. Make sure that the antennae of the Base phone is tight and up . Check the voltage to the base phone - if adapter is faulty.
Also check the handset for any loose fittings on the antennae.
If the problem does not resolve then you need technical help to check if the operating frequency or the signal processing is weak and faulty on the base unit. Best you can remove base unit and look for any loose links in RF section or shielding faults in this section that picks up stray signals.
Jan 22, 2011 | Audio Players & Recorders
No signal
Try this first
1. try to cover up any part of your phone with your bare hands. Look for a spot where the phone signal gets weaker if you cover a particular area. If that is the case, then you simply need to hold the cellphone in another position. 2.Second, try to change your position or location. There are many factors that affect cellphone signal strength, one of them is the space. If you are inside a closed location, go out and see any improvements in the signal. 3.Third, you can try to detach the SIM card from your phone and turn it off. After 5 minutes, put it back and see if the phone no signal problem is still going on. Or, you can change your SIM card if you have a spare one with another network say Verizon, Smart or At &t. If all these cellphone no signal tricks won't work, then your phone is probably broken. Bring it to a nearest cellphone repair center.
Jan 09, 2011 | Samsung Cell Phones
I bought it in USA, and I'll bring it to Indonesia (South East Asia). How about the callibration signal ? Could I get a good signal in Indonesia ?
Go into the settings "mode" and set the "city" to "BKK" Bankok.
Sorry, I've no information on the signal strength where you are.
Aug 14, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
Cellphone no signal
In your phone there will be a inductor antenna which receives signal. The inductor might not function properly. Contact service persons for that. But before tat in settings - Network selection select manual and check if it shows any networks. If it shows then the area has limited or no coverage.
Regards, Kesav
Mar 02, 2010 | Nokia 6300 Cellular Phone
What is the police channel
sorry but an average D/C radio can't pick it up. do you think the cops are stupid enough to have an average joe (no offense) pick up a radio scaner/D/C radio and let them get tracked. they learned that lession a long time ago. the average d/c radio gose from 550 -1400 the cops are out side of that rang, all the time. Also it changes from city to city/districs...
May 30, 2009 | Radio Communications
Need to disconnect XM Tuner
the xm receiver is in the left rear quarter of van looks like between wheel well and rear of vehicle this is drivers side
Jul 17, 2008 | 2007 Honda Odyssey
No network signal
Here is your solution. U need to open it with china screw-driver set. Then put a three fold paper under the two main ICs. CPU and UEM which both are looking same in PCB than tight the screws properly. This is caused by uncertain pressure on PCB. The PCB got bent and signal runs up quickly.
Don't forget to give yr vote for this..
Jan 05, 2008 | Nokia 3100
Sony Ericsson K700i Cellular Phone Logo
100 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
