Question about HP LaserJet 1320 Printer
Will not print Photoshop file
I have a HP LaserJet 1320 printer. The printer is attached to a MacPro computer running MacOS 10.4.11, via Ethernet and a HP JetDiret 175X print server.
It will not print a 8Mb Photoshop file. After about 10 minutes, the printer will print multiple pages of code. I have to pull the tray out to stop the printer. The orange cancel button has no effect. I have to turn the printer off to clear the job. However, other files will print on the HP. And, this file will print on a Brother printer attached to the network and an Epson R280 attached by USB.
I also run Windows2000 on this machine, using VM Fusion Version 1.1.2. The 1320 will print a WordPad test file. It will print the default image installed in the “My Pictures” folder. It is a 10k, but takes about 5 minutes to print. When I tried to print the file in question, the system returned an error message, but eventually printed the document as a series of pages of code, similar to the output from the Mac OS. As with the file running under Mac OS, the Windows printing could not be stopped with the cancel button and the printer had to be turned off to clear the job.
Please help me solve this problem.
Thank you.
Jim K
  • 3 more comments
  • jimkahnw Oct 31, 2008
    Yes, this is a PostScript Printer, but that shouldn't matter. I've used other PS printers and a 10k file should print instantly.
  • jimkahnw Mar 27, 2009
    Thanks, but the printer is another room, so a USB cable won't reach. I suppose I could move the printer for testing, but that won't solve the problem. It shouldn't matter if it's networked or direct connected.
  • jimkahnw Mar 31, 2009
    The printer seems to be operating normally. It does take a bit of time to print large bit map files, but I'm thinking it's the limitation of the printer. We had a power failure a few days ago and I'm thinking that reset the print server.
    Also, I appreciate the email address for Mac help. When I contacted HP about the problem, they wanted $40 for the support call. For another $50 I would buy a new Brother printer and be done with HP.
    Thanks for your help.
    Jim
  • michel_photo May 11, 2010
    Have you checked to see how much memory needs to be installed on the 1320 for it to accept an 8Mb bitmap? If you have only 8Megs installed the available memory runs around 5.58 See also the following from HP knowledge base about a print server causing similar prbs:
    Mar 22, 2008 22:53:10 GMT N/A: Question Author
    From HP Knowledge base
    Author Subject: LaserJet 1320 won't stop printing jibberish
    Lawrence Pry
    Mar 22, 2008 18:56:35 GMT
    LaserJet 1320 prints 1 or 2 lines of jibberish until it runs out of paper. No print jobs showing in printer folders. I deleted printer and drivers and then reinstalled, to no avail. Printer connected to Linksys wireless router and Trendnet wireless print server. Neither wired desktop or wireless laptop can print.
    Well, it appears to have been a print server issue. I disconnected the power cord from the print server on a lark and when I put it back in, the printer was no longer going haywire. The print server system manager showed the printer as "Idle" with zero print jobs. I was able to print from the network computer. Looks like that's the end of that.
    Some users also reported that a corrupt PSU (Printer Setup Utility) file could cause similar problems.
    Also: You could also try emailing laserJetMac.Support@HP.com with your problem.
    Last thoughts: have you tried accessing your jetdirect by its IP adress in Safari ?
    The other printers you mention are host based i.e. will use your MAC memory and CPU so you would not see a memory problem.
    Have you tried printing by plugging the HP on a local USB port?
Have you check to see if this is a postscript driver you are using?
Posted on Oct 31, 2008
My hp laserjet 1320 printing is printing too slow
If you're running a Mac, when you try to install the LaserJet 1320, it may suggest that you use the driver set for "HP LaserJet 1320 Foomatic/pxlmono." Do not use those settings. I had to reinstall my 1320 recently and since it said that was the recommended choice, I selected it. If I printed just text, it worked fine, but even a tiny 50KB image would take 5 minutes to print. When I reinstalled it again, I selected the option "HP LaserJet 1320 series," and everything works just fine now.
Apr 12, 2012 | HP LaserJet 1320 Printer
I have an hp 1320 laser jet printer but it cant be recognized by all the computers in my office. i have tried to change both usb and parallel cables but nothing is happening . what could be the problem?...
Have you connected it via Ethernet and installed the software on your office's server? If not then you will have to set it up as a USB or parallel on one pc and then all the other computers on the network will have to print to the IP address on the network of the PC it is connected to and then set up each machine to access that printer.
Aug 24, 2011 | HP LaserJet 1320 Printer
Can't install hp 1320 printer
Hi downward_man,
Here's the instruction on how you will install your HP Laser Jet 1320 Printer:
1. Access the HP hardware support site to retrieve the HP LaserJet 1320 driver download.
2. Click the link that represents your computer's operating system.
3. Scroll down the page, and click the "Download" action, below the "Driver - Universal Print Driver" table. Opt to save the driver, as the download file has the setup application that is needed to install it.
4. Double-click the setup application's icon from its new file location on your hard drive. The HP installation application will open automatically.
5. Click "Next" to proceed to the first installation steps.
6.Select all of the HP recommended installation options, and click "Next" to begin copying the driver's files and components to the computer.
7. When the HP installation wizard asks, plug the HP LaserJet 1320 USB sync cable to the USB port, located on the back of the printer hardware. Connect the other end of the cable to an open USB port on your computer.
8. Click "Finish" to complete and conclude the HP LaserJet 1320 series driver installation process.
Hope it helps.
Thank you for using FixYa.
Jan 27, 2011 | HP Laser Jet 1320 Printer
My HP Laserjet 1320 won't print even modest sized PDF files. The Printer Window says "Error-Printing" I've had this problem for years. How can I get my printer to print PDF files? I increased the memory...
If you are using a PS (post script) print driver, delete it and install the PCL driver (PCL5 or PCL6 if available). May help, not positive. I have seen lots of pdf printing problems with PS or incorrect model drivers.
These drivers are free to download at "support.hp.com"
Feb 06, 2010 | HP LaserJet 1320 Printer
I am failing to install the HP Laserjet 1320 printer without a CD
Kindly go to www.hp.com, serach for the printer name then click on support and driver, then download the driver from there, it is free
Sep 18, 2009 | HP LaserJet 1320 Printer
Wireless printer doesn't print (HP LaserJet 1320 NW)
GO TO PRINTER MENU AND CHECK THE JOB IN QUE AND CHANGE FROM OFFLINE IT TURNS TO READY
Nov 25, 2008 | HP LaserJet 1320 Printer
1320 not printing all the time
Your USB cord may be too long, or you have too many USB devices running. Try removing any other USB device, except the printer and do a test print.
Nov 17, 2008 | HP LaserJet 1320 Printer
HP Laser Jet 1320 Printer installation
Just downloading the PCL5 driver was not enough for my computer. Maybe it is enough for other users' computers. But in addition to downloading the drivers, i had to also download and install the "HP Laserjet 1320 plug and play print driver solution" at the bottom of the driver list. Save the file to your desktop, double-click it and follow instructions to install, then reboot. Then when I checked my printer list, the HP Laserjet 1320 was there. I printed a test page, and now i am good to go. Hope this helps.
Aug 05, 2008 | HP LaserJet 1320 Printer
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
Problem HP 1320 not responding
Try changing to a new USB cable
Jan 31, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
570 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
