Question about Xerox CopyCentre C118 Copier
Xerox c118 error
Required support for xerox c118 E1-6000
  • Anonymous Feb 13, 2009
    ???°??????µ?²?°?µ?? ?²?¾ ???Œ?Ž?·?µ???µ, ?²???´?°?µ?? ?¾???¸?±???? ??1-1000 ???±?µ???°?Ž ?±???¼?°?³??, ?¿?¾???°?·???²?°?µ?? ??1-6000. ??°???¸?½?°?µ?? ?²???´?°?²?°???Œ ?¾???¸?±???? ?¿???¸?¼?µ???½?¾ ?¿?¾??»?µ 50-70 ???¾?¿?¸?¹
    The error of displays ??1-1000 after paper elimination shows to error ??1-6000 jams in fuser. Jams after 40-60 pages
  • 79 Answers
Hi its a registration sensor error.. first u try to clean sensor.. again its not working better u replace a new sensor...
Posted on Sep 29, 2008
  • 239 Answers
Without seeing exactly the problem there can be a number of problem areas to case this problem.
On this machine, sometimes on the fuser, the jam sensor is a two piece sensor. The mount on the frame where the sensor is located and the flag actuator. The sensor, the plastic acuator warps and does not go up and down. This can cause major false paper jams.
Unless you are a service technition, the best way is to replace the actuator and even the sensor can resolve this problem.
This type of problem might even be related to the trasnport door not closing right.
Posted on Oct 16, 2009
Xerox c118 copy is not centered
Enter diagnostic: press "0" then "Start", enter System settings->CE Settings->MFC->Regist, enter 102 to adjust x-axis or 101 - y-axis, adjustment range x (-24 to 127), y (-72 to 72). 24 bit = 1mm. Good luck
Nov 20, 2013 | Xerox CopyCentre C118 Copier
Error U4-1000 (Xerox CopyCentre C116 copier)
U4-1000 Indicates Fuser on time failure
Follow these steps:
1. Check for paper on the fuser.
Y remove paper N proceed to step 2
2. Check the installation of the fuser assembly, make sure it is securely installed.
Y reinstall fuser N proceed to step 3
3. Remove the fuser. Check the conductivity of the contact points of the thermostat, are the contact points connected
N replace the fuser
Apr 12, 2011 | Xerox CopyCentre C118 Copier
Error code 008-111 and 008-131 out off paper but i have paper
The C118 errors you have are Registration Jam 008-111 and Fuser Jam 008-131.
You should order the Fuser Exit Sensor kit 015K60900 which is easy to install. Also, get the Registration Unit 059K45960
I hope this helps
Whit
Nov 22, 2010 | Xerox CopyCentre C118 Copier
Xerox error u41000
That is a fuser not warming fault. Replace the fuser module.
Jul 08, 2010 | Xerox CopyCentre C118 Copier
Required solution
Hello sir; the H8-1000 problem is at first tray paper size switch, check it up may be the switch not set it right.
Sep 06, 2008 | Xerox CopyCentre C118 Copier
ERROR WITH XEROX C118
Your machine is still working with msg? How many copies already made after displaying this?
Toner sensor may faulty cross check with same module.
Aug 28, 2008 | Xerox CopyCentre C118 Copier
Xerox CopyCentre C118 Copier Logo
957 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
