Need installation software for a hp ipaq rx4240 to sync with XP computer. Original install CD missing
  • Gunna_Do Sep 29, 2008
    Try checking this link for the software download http://h20000.www2.hp.com/bizsupport/Tec...
    Hope that helps.........
    No it doesn't. Been there, done that - can only find a fix for daylight saving (Not what I need)
    Try checking this link for the software downloadhttp://h20000.www2.hp.com/bizsupport/Tec...
    No it didn't. Already been there done that - all I could find was a fix for daylight saving.
    What I need is the full installation software so I can make the ipaq talk to a XP computer.
    Thanks.
  • 13,433 Answers
You need active sync
here
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync45.mspx
let me know if you need anything else? - you should need anything else about this but if you need anything else let me know.
Thanks,
Ekse
Posted on Sep 29, 2008
    Brigadier General:
  • 6,966 Answers
Initially, pls try:
  • Based on your post, you simply need to synchronize your HP iPAQ rx4200 to your XP PC. Since your PC is running Windows XP, your synchronization will be managed through Microsoft ActiveSync.
Additional information are available at
Post/comment back any updates/development. Appreciate your use of Fixya and good luck.
    Guru:
  • 1,894 Answers
This site has all the softwares needed by your phone in general.
thank you
  • 6,487 Answers
I have a pock pc ipaq 5550 and i need to hook it up to another computer where can i find the software i need to download before hooking up to my computer
You must have either ActiveSync (for Windows XP) or WMDC (for Vista and 7) installed on your PC, in order to have your device synchronized. Take a look here, and download and install the program that better suits your needs. Then, connect your device and you will be prompted to set your sync partnership data.
Hope it works for you.
Cheers! Carlos
Apr 20, 2010 | HP iPAQ H5550 Pocket PC
Hp rx4540.How to access the Boot loader mode?? .My ipaq just displays the hp logo on start up and then just freezes.Ive tried soft and hard reset.Help please
A factory reset erases all user-installed settings, programs, and data, and restores your HP iPAQ to factory settings.
CAUTION All user-installed settings, programs, and data are erased from memory with a factory reset.
To perform a factory reset and return your HP iPAQ to factory settings:
  1. Press and hold the OK and Rotate Screen buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
  3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ will now restart and power on.
If you have done the above and still no go. Then your main drive has probably failed.
Link below is a repair how to video
http://www.wonderhowto.com/how-to-repair-hp-ipaq-rx4200-rx4240-rx4500-rx4540-243534/view/
Mar 11, 2010 | HP iPAQ rx4240 Pocket PC
HP Ipaq h1940 won't sync with Vista
Hi. While holding power button, and pressing reset will do a hard reset to your PDA (reset the device to its factory default settings). So if your PDA is working well, don't do it. As for the syncronization with your Vista PC; Winodws XP uses the ActiveSync software for syncronization, and for Windows Vista, Microsoft developed a brand new syncronization software called "Windows Mobile Device Center". It can be downloaded here: (http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center-download.mspx). When you download/install this software to your PC, you should be able to connect your PDA to your PC without any problem, and definitely without changing any OS in your PDA or PC. Hope this helps.
Jun 01, 2009 | HP iPAQ H1940 Pocket PC
Wont work with a windows vista laptop??
you need to install the software that is the interface to the hardware. also depending on how old the hardware is it might not be compatible with vista
Apr 25, 2009 | HP iPAQ rx4240 Pocket PC
Ipaq rz1710
you need to install active sync in your window xp. You can download this software from http://www.download.com/ActiveSync/3000-2178_4-10031823.html?tag=lst-1&cdlPid=10714484
May 27, 2008 | HP iPAQ RZ1710 Pocket PC
HP ipaq rx3715
Have you tried other SD cards?  The box is uncheck for default install folder?  Maybe update the device.
Oct 13, 2007 | HP iPAQ RX3715 Pocket PC
Syncronizing
All you need is Activesync which can be obtained from this link.. http://www.microsoft.com/windowsmobile/downloads/activesync38.mspx and you need OUTLOOK installed and configured. It's important not to cradle the Ipaq until you are told to from Activesync. Try the following before you try to connect again... From your PC .......... with IPAQ cradled click on Start, Control Panel Double-click on System Click on Hardware, then Device Manager Click on '+' to left of Universal Serial Bus Controllers Click on '+' to left of Windows CE USB Devices Right Click on HP USB Sync Select 'Uninstall' Uncradle IPAQ Reboot PC
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
IPAQ 1715 not recognized
All you should need is Activesync. Try the following... From your PC .......... with IPAQ cradled click on Start, Control Panel Double-click on System Click on Hardware, then Device Manager Click on '+' to left of Universal Serial Bus Controllers Click on '+' to left of Windows CE USB Devices Right Click on HP USB Sync Select 'Uninstall' Uncradle IPAQ Reboot PC
Sep 08, 2005 | HP iPAQ RZ1715 Pocket PC
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
