Question about BaByliss FX44P
BabylissT44 Hair Trimmer
Fell on floor, spring came out, took apart, all parts look OK, but can't figure out how to fit back in
How to fit a trigger spring on a Ryobi Trimmer model PBC-3020
I have to go on general experience with my knowledge of Rybobi on this one. The handle of the unit where the spring is should have several screws in recessed holes. If you remove those the handle should split in two. When you do this make sure you are careful when separating it. There are usually some small parts that have specific places and you want to see how they seat back in there as you reassemble.
Aug 15, 2014 | Ryobi Garden
Putting a wahl 9307 back together
You will notice there is a little hook that the spring thing fits into on the device. You want the smaller part of the spring facing upwards and it should tuck in smoothly.
This is the smaller part of the spring facing upwards:
Then it gets tucked in as such:
Take note from the above photo that the square edges on the plastic piece go at the top of the blade piece and the rounded edges are at the bottom.
Then the bottom blade piece rests on top with the curvature facing upwards: putting-wahl-9307-back-together-g0fa4lo4hxabacpjggd4qk4j-2-5.jpg
The rest should be straightforward!
Jul 10, 2014 | Wahl 9307
How do i put back the blades on a wahl 9918C beard trimmer
You connect the blades together with the plastic part the correct way through the top of the small moving blade. The plastic part becomes a guide to keep the 2 blades running straight and true. Then engage the plastic part into the motor cam shaft and the 2 tension springs at the same time and wriggle it onto the screw hole posts and fit & tighten the screws. Lubricate and you're done.
Jun 22, 2014 | Wahl 9918-600 Beard Trimmer
I took apart the handle for my Toro Trimmer Model number 51972 and a spring fell out and I'm not sure where/how it goes back into the handle. I took it apart because the trimer runs but the spool does not...
Hello, Hopefully the exploded parts list can help you out... I've done the reassemble of a trimmer handle once and explaining it can get dicey. The only suggestion that helped me was to have scotch tape handy to act as a third hand when holding small items between two other parts. You don't actually wrap the item, just place it on a small piece of tape - when the item is in position the tape removes easily. Your diagram link is the top one. Good Luck!
http://www.poulan.com/node7925.aspx
Aug 01, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
How to put together the CST2000 and install a battery
Which part of the Grass Hog did you take apart? If you mean the spool head, that is easy to reassemble. The actual spool (the round part with the line coming out) goes into the cavity on the bottom of the trimmer, with the line poking out of the hole in the side several inches (not enough to hit the plastic guard). Then the cover (orange with the spring on it) fits on top of the spool so that the spring pushes on the spool and the two tabs on the side snap into the holes in the trimmer.
Unless you took another part off, that should be all you need to do to reassemble the Grass Hog. Turn it right-side up and turn it on to make sure everything works.
Jun 01, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Oster Power Pro Cordless Clippers I took the blade off, sm. long black plastic piece fell off. Wanted to change blade to ceramic. Can't get it back together don't know where black piece goes. Don't know...
The plastic piece is a blade guide and has a slot down the length of it which the spring locates into. Simply slide the replacement ceramic cutter under the spring
Sep 29, 2009 | Oster 76076-010 Hair Trimmer
Braun shaver model 5428
I have fixed mine. the pointy end fits in a hole next the the part that actuates the long hair trimmer (on the trimmer). this points out to the side of the shaver, and the rounded end fits into a little slot on the body of the shaver, slightly lower than the track the long hair trimmer slides along, and towards the top.its fiddly getting it all back together, but its perfect now. Dead pleased.
Sep 08, 2008 | Health & Beauty
BaByliss FX44P Logo
Top BaByliss Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a BaByliss Health and Beauty Expert? Answer questions, earn points and help others
