Question about Gateway GT4022 PC Desktop
Hot key for interface laptop to TV, via HDMI. Running vista on gatemay MG!
What do I need to do to make the TV Monitor work when I connect the laptop to the TV thru a HDMI cable. nothing happens.Is there a hot key, I am not sure what the symbol on F6 stands for
  • thumbs69 Feb 12, 2009
    Can't get Toshiba laptop to interface with larger tv (Emerson) screen
    Genius:
  • Gateway Master
  • 1,250 Answers
You have to press f6 key along with fn key on your laptop
Posted on Sep 29, 2008
How to Connect a Laptop to a Monitor?
Use a VGA lead. That is all there is to do, it will configure itself.
Oct 18, 2016 | Computers & Internet
Why wont my laptop connect to my tv via hdmi
After connecting the cable press the Windows key and the P key at the same time. The projector options will appear. Change from projector only to the desired configuration.
Aug 23, 2014 | Acer Aspire 5350 5750 5750g 5750z Series...
Emerson hdmi not working
Double check to see if your TV can support the resolution that your laptop is using. You can try reducing the resolution on your laptop to one supported by your TV.
If the laptop is configured to use the HDMI port as a second (in Windows 7, you can configure multi-monitor support in the display preferences) you will need to adjust the resolution for that monitor.
Failing that, try rebooting your laptop with the TV plugged in - I have found in some cases that this helps the system to propery detect a new display.
Dec 16, 2013 | Televison & Video
How to connect a toshiba m50 to a toshiba regza hd tv
They both have to have the same type of connection such as VGA or HDMI or connect a cable between them otherwise you will need some type of interface between them to make the connection.
Once you have the cables connected, get the tv remote and press Select Input to tell it where the signal is coming from (PC, VGA, HDMI). Reboot the laptop and the image will appear on the tv.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 21, 2012 | Toshiba Satellite M50 Notebook
Connect g60 to sharp 42" hdtv via hdmi
They both will need to have hdmi ports so that you can run a hdmi to hdmi cable between them. If not, you will need some type of adapter that connects between them.
Once you have them connected turn the tv on and press Select Input from the Remote and Select HDMI as the input (If you have vga connections there might be a PC or Computer connection for it).
Reboot the laptop and the video should be on the tv.
May 11, 2012 | HP G60-235DX Notebook
How to i connect my laptop into television with high definition multimedia interface
First what you need is a HDMI cable.
Second look for HDMI port at the side of your laptop. (It may not be the model of your laptop.)
Third look for the HDMI port on you T.V. (It may not also the model of your T.V.)
After confirming those connection on your T.V. and Laptop, you can just the HDMI cable to connect you Laptop to T.V. Also you need to choose HDMI on your T.V. settings and for your Laptop you can just switch the display by pressing FN+F4 or F5.
Hope It helps.
May 14, 2011 | Compaq Presario CQ60-204NR Notebook
How can I connect Screen to a TV via HDMI interface, whta windows OS do i need. The TV screen is blank on HDMI2. When I try to right click in desktop screen I can only find one screen definition. I have...
Right click on your desktop and hit personalize, then scroll down and go to display settings. If There is two boxes. one With 1 in it and two with 2 in it then you may just have to enable it. My laptop has a shortcut for it you have to hit fn then the f6 key at the same time to enable a second monitor :)
Dec 30, 2010 | Compaq Presario CQ60-220US PC Laptop
Hi, I purchased a Toshiba M363 in China. I am trying to connect it to my TV which only has HDMI connection. Although I have a HDMI port on my laptop which is also connected, I can't get my monitor to...
Have you turned your TV via the Input or Source on your TV or remote to HDMI? Also look at your "F" keys to see which one switches the computer to TV mode. Generally on Toshiba's it's the F5 key. Try pressing "Fn + F5" simultaneously while you have the TV set in HDMI mode.
Mar 20, 2010 | Toshiba Satellite Pro L300 Notebook
Conexant HD Audio no longer working with HDMI to TV
yes they did not load all the patches and drivers for hd audio. they are stupid or lazy. you need the patch from microsoft
Oct 19, 2009 | HP Computers & Internet
CONNECTING MY LAPTOP TO THE HOME THEATRE VIA HDMI
You need to press the FUNCTION key or FN key. While holding down that key, Press one of the F keys on top. The F key will have a picture of a monitor on it. Usually F4 or F10 key. So hold down the FUNCTION key and press that F key. That will display your laptop on the TV. You can press it a few time to switch between your laptop display or both.
May 02, 2009 | ASUS M51Sn-C1 Notebook
Gateway GT4022 PC Desktop Logo
399 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
