Question about Neff B1421 Electric Single Oven
Neff b1421 my oven door won't close properly and is losing heat does anyone know how to tighten the hinges - Thanks!!
  • Anonymous Dec 05, 2008
    Mine too! I have been told you cant tighten them they need bending back which I cant seem to do so I am now looking to just get new ones but omg they arnt cheap! Ebay here I come!
  • Neff Master
  • 3,463 Answers
Replacing the door hinges is the only solution to this problem.
Posted on Dec 07, 2008
Opening door catches
pull down the door hinges there is a slot turn it and it will lock the hinge put the door back on turn the slots back
Dec 01, 2012 | Neff B1421 Electric Single Oven
Oven door does not close properly
When you say "oven door does not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 01, 2011 | Neff B1421 Electric Single Oven
The oven door doesnt close properly. Can I buy new hinges?
The simple answer is yes you can buy new hinges,
There are several places on the net where you can buy these.
Just enter NEFF oven door hinges in your web browser, and you should be able to choose from many listed.
Feb 17, 2011 | Neff Ovens
Need fitting instructions to replace door hinges as manual misplaced. thank you.
The user manual probably wont have instructions for replacing your door hinges anyway. The service manual would, but they don't generally supply those with the oven.
I'd need to know the brand and model of your oven in order to give advice on fitting, as would any other expert here. Some ovens have sprung tension hinges, others have pivot/swing hinges.
Oct 10, 2010 | Neff B1421 Electric Single Oven
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
Door does not close tightly ? problem with bottom hinges
Yep, sounds like the hinges/springs have been overloaded.
Dont know if it's a Neff problem in particular, but I had a Neff oven with exactly the same problem - it was already installed when I bought my house.
Spoke to Neff who advised this ocours if heavy things like a roasting tray with a heavy bird / joint in it is rested on the door whilst it's open.
Only cure is new spring/hinge units which are not cheap !
Sep 18, 2009 | Neff B1421 Electric Single Oven
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Neff Oven Door Removed Incorrectly
you need to lock the hinges to get the door back.
it needs some strength
lay door flat on floor
force hinge against the spring until right back and put the locking arm over. i use my feet for this!
Nov 29, 2008 | Neff B1421 Electric Single Oven
My neff built in oven door does not close fully
You probably need to replace the oven door hinges, as the springs are weak.
Jul 16, 2008 | Neff B1421 Electric Single Oven
Neff B1421 Electric Single Oven Logo
369 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
