Question about Sony KP-51HW40 51" Rear Projection Television
Sony XL2400 Rear projection LCD tv
We have a narrow pink tinged band at the top of the set. It is about 6 inches high and runs horizontally across the entire top of the screen, in more or less a straight line. It does not affect focus. We have been experiencing this for several months and I thought it might have to do with the lamp coming to the end of its useful life.
The lamp finally failed, and I successfully replaced it. The television is working fine, again, but the pinkish band is still there. Any ideas?
  • 1779 Answers
SOURCE: Purple band at top of tv screen
Please make sure you have the Lamp seated properly in the set. If you purchased just the lamp without the basket make sure it is Flush against the front of the lamp basket. The light path is being obstructed or not aimed properly. Let me know, hope this helps.
Posted on Feb 03, 2009
  • 87 Answers
SOURCE: Sony Shadow on top of screen
Please call sony Optical Block warranty extended to June 30, 2010
Posted on Apr 14, 2009
  • 135 Answers
SOURCE: Pink bar across top of tv screen
This could be from 2 things. 1 is the optical block is going bad or 2 you got a peice of dust blown in from the cooling fan and its blocking the color filter internally. If you are capable you can take the tv apart and blow compressed air into the color block and remove the dust. Hope this helps
Posted on May 25, 2009
  • 132 Answers
SOURCE: my sony KDF-50E2000 TV has screen message coming
Yes XL2400 is correct number. Replace Lamp message is a timed message that will reset and turn off if you unplug TV when lamp is removed and replaced.
Posted on Mar 02, 2010
  • 171 Answers
SOURCE: I have a sony KDF-42E2000
ok if you just replaced the lamp and you have the message for the lamp you will need to reset the lamp timer here is the link
and for the tint color in your sreen well that is a issue with the LCD chips it looks like they are burning out and this problem will get worst you need to replace the OPTICAL BLOCK
check this link out it will help
Posted on Oct 08, 2010
Sony bravia internet tv has a pink horizontal band across the screen
If the line is Horizontal then you deffinantly have a cable issue, replace the cable and that should do it, if it continues the problem could be in the port itself, if using HDMI switch to VGA or composite to test this theory. please keep me posted.
Dec 27, 2013 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv no cost! If I chose a 46" or 55" there would be a charge between $325
Dec 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Dark horizontal band at top of Sony KDF - 46E 2000 TV
rca ps2720lv blue is very dim any suggestions
Nov 14, 2009 | Sony Televison & Video
Green lines developing about every 6 inches going across horizontally with slight arch on end sony projection tv KP57WS500
This is convergence out ICs failure and will be replaced for correct picture in TV.
Let me know if you can solder parts in circuit board of TV with necessary tools to provide you IC number and store address, or call local TV tech for fix if you are not comfortable with TV repair.
Oct 31, 2009 | Sony KP-57WS500 57" Rear Projection...
Has pink/green horizontal line across top l corner
Hi,if your tv is dlp or lcd you will need to replace the light engine that's in charge of creating the image and colors, and when bad you 'll get discoloration or lines across image.
Oct 01, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Changed Lamp on KDF50E2010 now have pink band
Is this on all inputs.If so optical block could be bad.
Apr 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
