Question about HP DeskJet 3745 Printer
Color printing in hp 3745
I just bought a tri-color cartridge yet everytime i try to print a colored document, it comes out to be black and white. i checked the settings and there is no problem about it. it seems that the printer does not reconize the tricolor cartrdge that i put.
I need driver deskjet 3744
Posted on Oct 27, 2008
I put a new hp tri colour cartridge in my printer ....when it prints off test sheets it prints in colour but when i try to print off colour documents it only prints black and white
There's an option under your print setting for color or black and white. When you select to print a window will pop up. make sure that you have the color print selected. Hope this helps
Nov 10, 2013 | HP DeskJet F4280 All In One Printer InkJet
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
ipg@hplibya.com
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
The printer's black ink cartridge won't print without the Tri-color print cartridge
Most of the HP printers are designed to allow printing onlywhen all cartridges are installed and
have ink.
Install a new tri-color ink cartridge and printing will continue as usual.
My printer, which is HP, does the same thing as yours, until I replace the empty cartridge,
printing stops.
Feb 22, 2011 | HP DeskJet 3745 Printer
Hp printer 7450 won't print colored text from a word document. test page shows colors on the windows logo flag. changed the ink cartridge....color one that is....no help i will try to print something else...
It may be set for grayscale (black and white) in the print properties. Go into the print properties in Word and look for a color or black and white setting, either under Color Management or Advanced. Set it for color, and then print your color document.
Jun 19, 2010 | HP Photosmart 7450 InkJet Printer
I just bought a new printer today its a lenmark Z2300m Color Printer i only have color ink for it do i need black ink for it because everytime i try to print it comes out greenish
Under your printer preferences there is a way to print gray scale. SO even if your image is in color, it will print black and white. Every printer interface is different, but when you go to print, there's usually a properties or setting button that will bring you to another page from the initial print menu. here is where you would choose gray scale.
If you try for black with only a color cartridge, it'll come out a dark green or blue color. Or on some cases, it will tell you it's out of black and you can't print.
Sep 30, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
HP OfficeJet 5610 All In One alignment cartridges and no printing
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab101
Jun 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp 3745 prints only the red color
This is Romeet, id like to try and help. Assuming you have windows XP installed,
go to "Start", select " Printers and Faxes"
go to your printer ( HP deskjet 3745 ) and right click it and select properties.
Click on " Print Test Page ", tell me what color does the Printout come in.
B.Regds
Romeet
Oct 31, 2007 | HP DeskJet 1280 InkJet Printer
Empty ms word printout
Hi, You can try: 1. go to Start, Printer and Faxes, right click on your 3745, click on Properties, Printing Preference; 2. Check to see if you have any Advanced tab or button; 3. Check if you can set the printer to text only; 4. Check if you can set the printer to use black ink only. 5. In MS Word, verify through the use of Print Preview that your document is as you would want to be printed; 6. In some instances you may have to set manually text color in MS Word. While your document is open, click Ctrl + A to select all, then choose font color to "Black". Alternately, in your MS Word, you can click on "Format", "Font", "Font Color" set to "Black" rather than "Automatic" and set this as the "Default" setting. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | HP DeskJet 3740 InkJet Printer
HP DeskJet 3745 Printer Logo
137 people viewed this question
Seeker5211
Seeker5211
