Question about ATI RADEON X1650 Graphic Card
RADEON X1650 Pro Issue (Flickery Graphics on Boot)
A couple of days ago i bought 1GB Memory and an Ati Radeon X1650 Pro graphics card for my Dell Dimension 4600. The graphics card ran fine for 2 days as did the memory. Today I got another 1GB Memory and upgraded that also, the memory was rejected so I believe i may have the wrong memory this time, but then the graphics card started playing up evry time it came on the screen was dodgy and specles all over the display, strange colours and images.
ive taken the not acceptable memory out and the memory is now reading fine at 2GB as before.
Ive had to remove the graphics card and go back to my old one now - I dont get what could have gone wrong in between to cause that?
any ideas on whats happened?
  • 2 more comments
  • kris1982
    kris1982 Sep 29, 2008
    Great thanx, I'll try now and post back after with the results.
  • kris1982
    Ive tried the idea suggesed but no joy, system restore ran fine. it flickers and gives bad image even on the boot screens.
  • kris1982
    Reseat the card what does that mean
  • kris1982
    what does reseating the card mean? is the card faulty or does it just not agree with my PC do you think?
  • 19,396 Answers
If reisntalling drivers did not help,
  • try removing the card from slot,
  • if you have a different AGP or PCI video adapter, or on board card,
  • plug back power and restart, then you switch back to your Radeon, and if required install drivers again.
see if it works
Posted on Sep 29, 2008
  • Ginko
    Ginko Sep 29, 2008
    Do as suggested:
    Unplug power cable
    Reinstall Drivers
    Remove card from AGP slot , test different one and put back.
    Test different RAM.
    If you get the problem after all this, the card may have been damaged, and it is faulty, you need to test it on a different PC.
    Brigadier General:
  • 6,966 Answers
I would suggest (as others have probably suggested also), replace the video card. it is still under warranty being only a few days old. Artifacts, splotches or noisy video in graphics card often indicates the memory problems (of the video card).
Post/comment back any updates/development. Appreciate your use of Fixya and good luck.
  • Louie  Role
    Louie Role Sep 29, 2008
    You could of course try cleaning the pins of the video card with a pencil eraser (but should not be necessary on a new card).
  • 1,879 Answers
If at boot-time (where the screen displays the graphics card and then the BIOS info) you get funky colors or scrambled image, It's the graphics card.
Reseat the card or better yet, try it on another computer.
    Guru:
  • 859 Answers
Did you only have flickery graphics on boot alone? If so, this may be a loose insert or failiure in the hold down brace. I would suspect a loose pin. Do you have DVI/Svideo/VGA plugs on this card and if so were you using the VGA plug or the DVI to VGA adapter?
However, I would uninstall the ATI software, reattach the video card after getting the latest drivers for your ATI card from AMD. Give that a try. If that fails try the suggestions below.
Next, are you using an AMD CPU and an Nvidia chipset? If so, you should consider using a GeForce AGP card.
On your memory install. So long as the ram chips match you should be okay. But, Windows cannot see 4Gigs of Ram only 3. So a 1 Gig Ram Chip may be the addon to use.
As long as the Display only flickers momentarily at bootup, and is otherwise normal, you could continue to use the ATI display adapter. Still, as I recall the x1600 series ATI card had some real problems. Many fail really early.
With that in mind, I'd suggest you get a Nvidia GeForce 6000 for an AGP solution, and get an XFX card if you can for their warranty that is transferable.
Regards,
Worldvet
  • Glenn Rogers
    Glenn Rogers Sep 29, 2008
    You are going to have to dump this card. Remove the software too. Then, get an GeForce AGP card. You'll be trouble free after that.
    WV
  • 6,487 Answers
THis can be problem with the software fo your video card, first thing to do here is to put the video card back in and try to go to safe mode and install or update the driver of the video card and if you can also do a system restore that will also be helpful....
Hope that helps..........
  • Mark Gil
    Mark Gil Sep 29, 2008
    IF you already do a system restore , try to boot on Safe mode and then uninstall the video card and reinstall it back using the driver from the setup CD, but if you can also download the latest driver from ATI site and use that one ....
  • Mark Gil
    There's really a possibility that the video card is bad, since its still anew video card I may advice you to repalce this video card at this time so we can isoltae the problem, because if the replacement video card work fine so we already know that , this video card is the problem....
    Guru:
  • 1,894 Answers
Did you make sure that both the RAMs belong to same frequency?
u get optimum efficiency only if both the frequency match
  • dewan nafees ahmed Sep 29, 2008
    if the graphics card is the one making problem then try to keep the CPU open for one day and provide enough cooling. see if the problem persists.
    also try the combination of new memory alone and the graphics card. see what happens and get back to us
    if flickers in boot screens then it is a hardware fault for sure.
    either a faulty cable or a loose connection of cables.
    try a different cable. and tell us what happens.
    make sure you dont keep any highly magnetic components and transmitting equipments like mobiles near the monitor.
    let me know what happens.
    thank you
I need driver for graphics card ati radeon MAYA 9500 pro
Download the most current drivers from the manufacturers website.
Mar 22, 2012 | ATI RADEON X1650 Graphic Card
ATI Radeon X1650 Pro overheats and videocard shuts down
check if the games take too much memory so that the card not able to work, if you used to play it before without problem, check the card fan if its working,and at the same time check your computer cooling if its cool enough.
Jun 14, 2009 | ATI RADEON X1650 Graphic Card
I installed the ATI x1650 but the monitor is blank when I turn on
Yes the card does support the screen. If you have blank screen right from turn on, chack that you have not plugged the monitor into the onboard graphics port instead of your Radeon. If you have plugged it into the right port then you have hardware problems. Could be any of the following:
1. Monitior
2. Video Card
3. System memory
4. Motherboard
5. Powersupply
6. CPU
Try a different monitor and get back to me if you want troubleshooting tips.
Cheers
May 09, 2009 | ATI RADEON X1650 Graphic Card
Can i run ati radeon x1650 512 on asus k8N motherboard
Yes you can run the AGP version of the Radeon 1650 pro on your system. It is always best & recommended to upgrade memory in pairs. You could upgrade to `gb by purchasing a 1 gb kit which would be 512 x 2. That way you have a matching pair of RAM modules. As for a cpu upgrade you can go to the Asus website and see what cpu's are supported by your motherboard. Hope this helps & please remember to rate my answer. Thanks.
Jan 24, 2009 | ATI RADEON X1650 Graphic Card
ATI x1650 Pro Stops!?
For this card they recomment at leat a power supply rating of 450 watts. If you have lower than this then I would suggest upgrading the power supply. A 550 watt psu is reasonably priced and should give you plenty of power for future use. Hope this helps.
Oct 17, 2008 | ATI RADEON X1650 Graphic Card
ATI RADEON X1650 Pro Problem
The graphics card might not be working in sync with your processor. Get it checked WHY this is happening. Probably a faulty connection somewhere. See if you can find one before getting it checked.
Sep 13, 2008 | ATI RADEON X1650 Xt, (256 MB) Graphic...
the card you have is a PCI express 16X your board is for PCI express 8X. I think some cards can run at a slower speed but I believe you have the wrong card for your board
Jul 29, 2008 | ATI RADEON X1650 Graphic Card
ATI RADEON X1650 Graphic Card Logo
106 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
