Question about Raymarine Raychart 435 GPS Receiver
Raymarine GPS RC435
Hello
After a few years without any problem (4 years), last week end, and yesterday, we have a problem ... the GPS say : NO FIX. Last week
end, after 4 hours ... the GPS find a position, and yesterday, no position during all the day. In the GPS configuration, i see just
1 satellite in the list ...., i see the number of the satellite change (and the position of the satellite), but no signal.
For information, the GPS is on an Beneteau OCEANIS343.
thanks for your answer.
Bye
  • Catalina 309 Mar 29, 2009
    I have the same problem. Have you found a solution? My quess is that the GPS receiver's battery died. Is there a way to replace it?
    Thank you.
    TG
3 Suggested Answers
  • 16 Answers
SOURCE: Raymarine GPS system HALT ! URGENT PROBLEM
To get back up and running you are going to have to reset the unit. This is from the handbook:
Note: Take care - factory reset clears allWaypoint and Route databases.
➤ To perform a factory reset:
1. Power off the unit.
2. Press and hold CLEARwhilst powering up until <Erase backup procedure>
is displayed.
3. Either press CLEAR to abort Factory Reset and resume normal
Power-Up or press ENTER to continue Factory Reset.
4. Press ENTER again; the unit restarts as for a first time PowerUpwith
all values reset to their original factory settings
When you hit port and have an internet connection, make sure you are running the latest software version, currently listed online as version 1.09. You can download it here:
http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_adp.php?p_faqid=965
Posted on Dec 28, 2007
  • 43 Answers
SOURCE: GPS antenna
If your old antena is a Seatalk or NMEA antena you can use it for your C80
If you GPS antenna is older than five year change it.
Posted on Oct 31, 2009
I have problems with my plotter Raymarine Rc 435 chart plotter.This plotter can not location my ship to do.What is problems?
Be sure there isn't any aluminum in close proximity to your GPS antenna, or that your antenna is not to close to other powerful electronics. Aluminium reflects electromagnetic signals and other electronics emit EM fields as well causing disruption of your GPS signal reaching your antenna.
Sep 26, 2014 | Raymarine Rc435 Chartplotter
System haild
Take the Raymarine Rc 435 Chartplotter to a system or computer engineer for repairs.
Jan 22, 2011 | Raymarine Rc435 Chartplotter
My Raystar 120 GPS keeps losing its fix.... the fix comes b ack a few minutes later, but then i lose it again. I have tried a cold restart, but the problem persists. Ideas?
Guys, most likely the litium battery is eol. Buy a new litium 3 volts battery for 3-4 euro's with soldering points . Use a pair of scissors, note the plus and minus side of the poles and carefully cut out the battery leaving enough metal to solder a replacement battery. Solder the replacement battery, and the problem is fixed. You're ready for another 6 years of fun saving 300 USD for a new GPS!
Oct 10, 2009 | Raymarine Raystar 120 GPS Receiver
Rc435 works but looses it's fix periodically
The gates are to be removed only for surface mounting, and are there to prevent water ingress under the base. The cable would be crushed if the gate was not removed and the base was screwed onto the cable...
The antenna is powered from the base unit via the cable, but that's a simple DC circuit. The RF circuit is carried in the 'normal' way by the coax cable.
If you can clean the soldier from the scrunched fitting and get a good mechanical support, the soldier will provide the electrical contact. Be careful not to overheat the contact, and be sparing with the soldier when you reattach the braid. The braid is likely to be damaged / oxidized for some distance from the damage, so be sure you have enough slack in the cable. Raymarine's web site says you should see 4.8 / 7.2 Mega ohms of resistance across the antenna plug leads (different ohms depending on polarity of test leads) Good luck.
May 30, 2009 | Raymarine Raychart 435 GPS Receiver
is displayed.
Sep 10, 2007 | Raymarine Raychart 435 GPS Receiver
Raymarine rc435
ripoli, This should site should help you now and in the future: http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_alp.php?p_sid=8fkbDBti&p_lva=&p_li=&p_new_search=&p_accessibility=0&p_srch=&p_sort_by=&p_gridsort=&p_row_cnt=696&p_prods=&p_cats=&p_pv=&p_cv=&p_search_type=answers.search_nl&p_nav=foot&p_li=&p_page_head=1&p_page=1&p_page_foot=1 Good Luck, Tim
Feb 05, 2007 | Raymarine NMEA 0183 (E55059)
Raymarine Raychart 435 GPS Receiver Logo
127 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
