Konica 8050 jam setion 9
  • sam gerban
    sam gerban May 11, 2010
    if can enable the jam code .in the 25 mode
    so that you can pinpoint the th,e area,
  • 145 Answers
Need to activate jam codes on the machine so you can pinpoint the problem.it's in the 25 mode dip switch 11-7 to on
Posted on Oct 18, 2008
I need a technician in metro atlanta who has expierence with konica minolta c500 or 8050
contact the manufacturer we have no idea who does that service for them anywhere
Nov 17, 2015 | Konica Minolta Bizhub Pro C500
I have problem witm color copier konica minlta 8050 with error sc28-02
Check the yellow drum charge corona to get that open the front of the machine unscrew the front section then pull out he charge corona for yellow do not have open the unit to expose belt and drum. ensure they all are seated properly
Feb 02, 2011 | Konica Office Equipment & Supplies
Error C500.
PROBABLE CAUSES:
1. Insufficient airflow during idle causing internal machine temperature to rise. Toner is backing up or solidifying in the cleaning unit box for the transfer belt causing the transfer belt drive motor (M18) to bind.
Replace the Belt Cleaning Unit (p/n 65LA R702 00) and install attached Special Printer Control firmware (version 51-PBF0 for the 8050/CF5001 and version 12-PBF0 for the bizhub PRO C500). This firmware keeps M11 (Transfer Belt Cooling Fan) ON for a period after the copy process has completed which helps keep the internal temperature at normal levels. The firmware can also be download from the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'.
Note: Firmware version 51-PBF0 is primarily for the 8050, but can be used for the CF5001. When using the ISW tool to download the firmware please select the 8050 from the drop down. If the CF5001 is selected the ISW tool will not see the file.
2. The paper exit fans (M61/M62/M63) DIPswitch is not turned ON.
Set software DIPSW 21-0 = 1 to enable the paper exit fans.
3. Dirty or failed transfer belt drive motor encoder disk sensor assembly.
Clean the transfer belt drive motor encoder disk and sensors. Replace the assembly (p/n 65AA -909 1E) as necessary.
4. Failed M18 transfer belt drive motor.
Replace M18 transfer belt drive motor (p/n 26WA 8001 3).
Jan 18, 2011 | Office Equipment & Supplies
We have HP Photosmart 8050. We had a paper jam but was able to clear it. However, it will not print from the computer. We were able stat and color alignment page, so we know paper is getting through and...
There will be something in there, whether it is toner/ink over a sensor, a paperclip/staple, or a tiny scrap of paper.
The trick with this one is patience, methodically strip it down as far as you can, checking as you go for stuck material, and once you have gone as far as you can put it back together nice and slowly, looking for broken connections and loose bits, then try it again.
If there is nothing in there then the printer has something broken and needs looking at by a technician, in this case you should turn to your warrenty.
Oct 29, 2010 | HP Photosmart 8050 InkJet Printer
Display permanently indicates
Unplug the Printer and Disconnect it from the Power Supply. Then Turn it Back ON, after few minutes say 30 minutes, that would fix the Problem.
If Problem Persists, Check the Machine Once again to make sure that you do not have any Paper Jam.
Refer the Manual to Clear Paper jam, if any. If you do not have the Manual, Revert to me and i would be glad to Offer you the Manual.
In fact, Check Below Link to Clear Paper Jam :-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00438945&lc=en&cc=us&product=454816&dlc=en#
Now,
If there is No Paper and still the Message is there, more likely, the sensor has gone bad and needs replacement.
If under Warranty, get it replaced without any Charge unless Hp would charge you more than half the amount to get this Fixed. Still not a Bad idea to call and have a Quote and if the amount is too high, do not shy of asking for exchange in lieu of this. They could Offer you a Nice Discount as Christmas is already here :)
Note - Also Try to remove the Cartridges and again Re-Seated them Properly.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 22, 2009 | HP Photosmart 8050 InkJet Printer
Konica 7222 f28-3 code
part # for the t/s unit is 40la-2600. if you need it I can order the part for you
Aug 13, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Calibration error how do I fiw it or reset it on
Try to check inside the printer. the sensor maybe blocked by small paper thats why paper jam error appear.
Aug 13, 2009 | HP Photosmart 8050 InkJet Printer
Tech support
F45-20 Color registration correction
results in abnormality.
Printer control board (PRCB)
Color registration sensor /F (PS8)
Color registration sensor /R (PS9)
May 16, 2008 | Office Equipment & Supplies
I have an HP Photosmart 8050 printer that gives me a paper jam message after each print job
i,d suggest that the paper sensor is faulty.
try unplugging your printer, and setting it back up.
alternatively, hold down the paper-jam button if it,s flashing.
mike @ compurepair.
Feb 24, 2008 | Computers & Internet
51 people viewed this question
jasbo
jasbo
