Hi there! I bought a 320g Toshiba external hard drive in April 2006 and it worked a treat, however I tried to switch it on over the weekend and you can hear the bits spinning inside and the blue light comes on on the box, but my laptop doesn`t recognise it under "my computer". I have tried a few other USB`s as well but no luck. Is there any way I can get this fixed? I had a look on the box, but I can`t see any reset button, etc. I really don`t want to loose all the data currently saved on this unit!!!! Regards, Nico
  • jvrn78 Sep 29, 2008
    Nathan,
    Thanks for your prompt reply. I have two laptops, and tried it on both, but none of them is picking up the external hard drive. I have never dropped the unit and it was never put in direct sunlight, the only thing that could have been the problem was, for some strange reason we experienced some voltage drops in the house the last few weeks where the light went from dim to normal a couple of times. That`s the only problem / reason I could think of. Do you reckon there`s still a chance of retrieving the data successfully, or should I have a word with the data clinic?
    Regards
    Nico
    Sergeant:
  • 208 Answers
First i want you to make sure that the external hard drive is working. Try it on another computer and see.
If it works in other system, then Right click ' My Computer ' in your system and select
' properties' and then ' Device manager' and scan for the hardware......
Hope this will work only when your external hard drive works on other system but fails on your system.
If other system also not able to detect the external hard drive , then it has failed.
Failure of these units is often (but not always) heat related.
They are also more likely to suffer impact damage as it's far easier for these drives to fall out of bags or off of tables etc.
Recovery possibilities: Entirely dependent on the nature of the problem. Heat associated problems are often easier to tackle than impact damage problems.
You can fix this problem and recover your data,
by calling DATA CLINIC 0870 140 2525
http://www.dataclinic.co.uk/
They will provide you with further assitance.
Hope my info fix your problem,
Thanx for using fixya,
Cheers.
Posted on Sep 29, 2008
I have a wd elements external hard drive....My Pc no longer recognizes it. I have much of my vital info and project data saved on it. How do I fix it with out reformatting it .....ps I already reinstalled...
I had that prob ages ago. I fixed by doing a quick format. By quick formatting your drive is not wiped.
Once quick formatted do not put anything on the drive and run software recovery software of some sort.
It is very likely you will have to purchase that software unfortunately.
There may be other courses of action, this one did work for me though. Do remember if you do this that if your drive contained 320g of data you will need 320g of space free elsewhere to recover to.
Nov 15, 2011 | Western Digital Elements powered by WD 320...
When I plug my 320G WD Elements there is no WD icon on my windows or my computer window. thanks
Have you used this HDD before?, it this is the first time?
Sometimes you have to install the WD Smartware Software. In the case of the 320G, which are the first HDD released, The computer should detect them automatically.
Try with another USB port. Do not use a USB multiport because it won't power the HD.
If it doesn't work on your computer, try it on another one. This way you can discard the possibility that the HDD is damaged.
God BLess You!!!
Feb 14, 2011 | Western Digital Passport 320GB External...
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
I have a satellite A215-S5848 toshiba laptop. The hard drive is 200GB HDD. The hard drive is nearly full so I bought another notebook hard drive:320G, 5400 RPM 8MB Cache. Could this be installed in my...
Most laptop computers have a place for only one hard drive. If you have the capability of installing two, then you can do it.
I would clone the old drive to the new one--you will need an external USB adapter to do this. Then you'll have more room. You also can offload a lot of your stuff to CD or DVD or an external drive to free up space.
Oct 19, 2010 | Computers & Internet
Hello! i got a problem with my external hard drive. My 4G flash is recognized but my 320G hard drive is not recognized in my desktop. I tried to plug the 320G hard drive in my laptop and it was recognized....
The external drive needs to be initialized from your PC. To do this, right click your My Computer and choose Manage. At the left panel click on the Disk Management. The list of available drives will show on the right.
Right click on the drive and select create partition (primary partition). After you've selected your partition , now you need to format the hard drive. Choose quick format. Right click again on the partition you've just created, now select "Format" and select NTFS. Click ok and it will guide you until it is finished.
If you need further assistance, just let me know.
Oct 12, 2009 | Buffalo Technology Computers & Internet
Western digital 320g elements portable won't work
Hey,
try connecting it o another computer and check
if not yet, use only the WD USB transfer wire supplied in the box.
because WD External HDD only recongize its own USB and none other.
May 03, 2009 | Western Digital Elements powered by WD 320...
External hard drive not recognised on my ps3??
Ok. Well this is easy! your hard drive is formatted in NTFS, ps3 wont recognize that. it needs to be fat32 find an XP machine not a vista machine.
download Swiss Army Knife and format the drive in fat32. you will loose ALL information in your external. you will need to back up anything you want to save and put it back after the format.
good luck!
Feb 09, 2009 | Maxtor Hard Drive
Seagate 320g internal hard drive
Hi-
How bout on device manager? right click on my computer icon then go to manage, go to disk manager and check the disk management and configure the new hard drive
hope this helps
Aug 16, 2008 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
