Question about GE PDS22SIS Bottom Freezer Refrigerator
GE Profile PDS22SISARSS
Hello
My GE profile bottom freezer (model number PDS22SISARSS) seems to be running all the time suddenly. It's currently set to 0F for freezer and 37F for refridgerator. The temperature seems to vary between -1F and 1F for the freezer and 36F and 38F for the refridgerator. The temperature seems to go up whenever it goes through its defrost cycle. Otherwise the fridge is always running.
However, when the freezer and refridgerator temps are at or below target and if I hit the temperature controls, the refridgerator stops running until the temperature goes back up above target. Then it starts again, but doesn't turn off again.
Any thoughts? Trouble shooting tips?
Thanks
Any thoughts?
  • 1462 Answers
SOURCE: GE Profile Arctic Side x Side Refrigerator PSC23MGNA
check that compressor is not cutting out on overheat and hence cooling stops. feel compressor when it has been running for some time and see if it over hot
Posted on Jun 18, 2007
22yooper
  • 828 Answers
SOURCE: Does not stop cooling down
Door edges being warm is caused by what is called mullion heaters that operate to prevent humidity from condensing at these points.
Some refrigerators have an energy saver switch. Turn this switch if you have one to the energy saving position when the humidity is low. Is anything freezing in the refrigerator? If so setting the controls to a little higher setting may solve your problem.
Posted on May 03, 2008
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
SOURCE: GE Profile - model PDS22 - constant clicking noise
Yeah, same problem. There are two capacitors that seem to be prone to going out. You can replace the main board, or (if you can solder) replace the two capacitors with slightly larger ones (radio shack mdl number 272-1030 works) just remember to bend them away from the heat sink if you go that route.
Posted on Jul 11, 2009
  • 1891 Answers
SOURCE: GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Posted on Feb 04, 2010
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
I have a GE Profile freezer on the bottom refrigerator model #PDS18SBMARBS. A fan was runnining on the inside of the fridge seemed to be between the fridge and freezer. It was very loud and now does not...
Could be a bad fan motor. A bad defrost part or a bad control board.
Check for ice buildup on the back wall of the freezer. If so you have bad defrost parts or a bad control board.
Enter your model number at www.appliancepartspros.com to find the exploded view to dis-assemble the freezer. You can also order parts from them.
Aug 20, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Freezer and fridge suddenly got warmer
I had a similar problem and had to replace my mother board and pump motor.
Feb 23, 2009 | GE Profile PDS22MHR Bottom Freezer...
Freezer isn't freezing all of a sudden but frig. side is still cold
There is a cheap repair manual for this model listed on eBay. The item number is 200262539606.
Premmy
Oct 14, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
I am looking for an installation guide for a new GE Profile, 25.5 cf, bottom freezer, refrigerator... model number PFSF6PKWBWW
Hi canmarboise,
I'm Harvey the Master Plumber.
You're looking for an installation guide for a new GE Profile, 25.5 cf, bottom freezer, refrigerator... model number PFSF6PKWBWW
There is only one place to go:
http://www.geappliances.com/service_and_support/literature/
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | GE Refrigerators
Ge refrig
I have a ge profile side by side. when it auto defrosts the water runs to the bottom and out the freezer door instead of down the drian??
May 31, 2008 | GE Profile Arctica Stainless Steel Top...
GE PDS22SIS Bottom Freezer Refrigerator Logo
177 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
