Question about HP Photosmart M525 Digital Camera
SD card keeps popping up when inserted in cama. SD card will not stay down in camara Says it needs to be formatted. It will not format. Never has this problem before How can I fix this
The SD card keeps popping up when inserted in camera. What is causing this. I took it out to develop pictures and now I can not insert it without it saying it n eeds to be formatted and this does not work. How can this be fixed?
    Scholar:
  • 54 Answers
The SD slot of the camera got damage somehow. The SD slot contains thin copper prongs that locks the card in place and comes in contact with the surface of the card. If these prongs are damaged, then it cause a read failure of the camera.
Posted on Dec 10, 2008
Cano camara d,int read my sd cart
Make sure that the card is formatted FAT32 in your PC and try it again in your camera.
Apr 09, 2014 | Canon PowerShot Cameras
Difficulty formatting new memory card for a Kodak Easy Share DX7440
The DX7440 works with MMC and SD cards, which max out at 2GB. While your 4GB SDHC card fits into the slot, it is electronically incompatible and will not work with this camera. You need to stay with SD cards, 2GB and smaller.
Dec 01, 2011 | Kodak EasyShare DX7440 Digital Camera
Hello. I have installed the sandisk sd 4Gb card into the slot in my lg pop but the phone does not see it. do I nee to do something? many thanks
You may need to format the memory card first before you can use it. Refer to the packaging and documentation of the memory card, or refer to your phone's manual regarding using SD cards. You may be able to format the card while it is in your phone, or you may have to insert it into the adapter and plug it into a computer to format it. The following link has walkthroughs of both methods of formatting an SD card:
http://www.ehow.com/how_4913062_format-sandisk-micro-sd-card.html
Jul 17, 2010 | SanDisk 4GB microSD High Capacity Memory...
How do i format my sandisk in my panasonic lumix FX40
Hello :
1: Insert the SD card into the multi-card reader on your computer. Most newer personal computers and laptops come with a multi-card reader. If you don't have one , then you should get one ! Just make certain that you insert the SD card into the appropriate slot. A multi-card reader picture is shown : There another types of multi-card reader , so you can choose the best one for you .b74156b.jpg
2: Right click once on the Windows "Start" button.
3: Click once on the "Explore" option.
4: Find the SD card in the "Folders" section of the window.
5: Right-click once on the SD card icon.
6: Click once on the "Format" option.
7: Make any desired changes using the options on the "Format" window. Default options are recommended, but it is possible to change the file system and allocation unit size. If you change any of these settings and want to change back, click once on "restore device defaults." To perform a quick format, click once in the "Quick Format" box. A quick format means only that all files will be removed from the SD card, but it will not be checked for bad sectors. A quick format is considerably faster than a full format, but neither takes too long.
8:
Click once on the "Start" button on the "Format" window to begin the formatting process. A warning window will pop up to make certain you want to proceed with the formatting of the SD card. Click one on the "Yes" button to move on.
9:
Click once on the "OK" button on the "Formatting" window that pops up when the formatting is complete.
10:
Click once on the "Close" button on the "Format" window to exit the formatting process.
good luck .
please don't forget to rate !
Apr 04, 2010 | Panasonic Lumix DMC-FX12 Digital Camera
Olymus 1gb sd card could not reformat
in this case Im sorry to inform you that will not be any data available on that card cause it should have been formatted before use...or ..it is damaged thats why it is not reads on it ...but a thing to try is to see if it is not locked on the side button ..for securing data ..at least after unlocking you can format it ..and use it ...
also see that it needs to be formated in FAT32 ..for to be usable in the camera
Jan 27, 2010 | Olympus FE-230 Digital Camera
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
Jan 02, 2010 | Canon PowerShot A530 Digital Camera
Eos 40d error 99
Error 99 can mean many things. Have you installed the latest firmware for the camera (version 1.1.1)? If you don't have, download it here (for equipment purchased in USA or Puerto Rico):
http://web.canon.jp/imaging/eosd/eos40d/eos40d-firmware-e.html
If you have the latest firmware, try this:
  1. Switch off the camera and remove the CF card and battery
  2. Keep the camera idle for 30 min
  3. Clean all the contacts of the camera (battery contacts, lens contacts etc) with an eraser. Do this keeping the camera facing down so that no debris fall into the camera.
  4. Attach the lens and insert the battery.
  5. Switch on the camera
  6. Insert the CF card
  7. If the error persists, format the card again
  8. If this does not work, try using another CF card.
Feb 06, 2009 | Canon EOS 40D Digital Camera
Card error samsung s730
I own a Samsung S730, i downloaded all the drivers on Vista Home, I tried formatting the SD Card but it says CARD LOCKED, and it isnt. Any solutions
Oct 25, 2007 | Samsung Digimax S730 Digital Camera
Sd card formatting
Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
Oct 22, 2007 | HP Photosmart R707 Digital Camera
Formatting SD card
Possibly either- or Take it back to the shop and ask them to check by inserting another card or card into another camera Get which ever it is play up replaced
Sep 04, 2007 | Vivitar ViviCam 3730 Digital Camera
HP Photosmart M525 Digital Camera Logo
269 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
