Question about Nintendo Wii Console
Wii hand sets not working - Nintendo Wii Console
    Problem Solver:
  • 19 Answers
Put new batteries in them. You need to sync them to the Wii from the HOME menu.
Posted on Dec 02, 2008
How to get the internet
Below are simple connection instructions from Nintendo's website on how to connect your Wii to the internet via wifi and an ethernet adapter.
Connect a Nintendo Wii to the Internet through a Wireless Router
1 Turn on your Nintendo Wii by plugging it into a power source and pressing the power button
Press the "A" button on your Wii controller to continue from the warning screen
Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
Click the "Wii Settings" box on the right.
5
Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
6
Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
7
Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
Connect a Nintendo Wii to the Internet with a Wii LAN Adapter
Insert the Wii LAN Adapter into the USB port on the back of the console.
Connect an Ethernet cable from your modem or router to the adapter.
Turn on the Wii console.
Click the "Wii" options button in the lower left hand corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options.
5
Select "Connection Status," then "Connection 3: None" and "Wired Connection."
Mar 05, 2011 | Nintendo Wii Console
How to use wii points
Here is step by step on what you need to do
turn on your Nintendo Wii Gaming System 2Make sure that your Nintendo Wii is connected to a wireless broadband connection. 3Go to the Wii Settings and follow the prompts under the Internet Setup screen. 4Once your Internet is set up and ready to connect and browse, return to the Wii menu. 5Point the Wii remote at the top right hand corner of the Wii Menu until the hand is over the Wii Shop Channel icon. Press the A Button to load the main page of the shop channel Once you are into the main menu of the Wii Shop channel, there are several options you can look at.
Jan 09, 2011 | Nintendo Wii Console
How to recieve internet connection
Hi. Here are the procedures on how you conect Wii to the internet
  • 1 Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
  • 2 Press the "A" button on your Wii controller to continue from the warning screen.
  • 3 Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
  • 4 Click the "Wii Settings" box on the right.
  • 5 Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
  • 6 Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
  • 7 Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
  • Sep 12, 2010 | Nintendo Wii Console
    Lost communications to WII remotes and board
    hi, my wii console works exept the little hand from the wii will not go on the screen, the remotes are programmed in and work fine so wondering what the problem could be? if its the sensor bar or something else and can it easily be fixed? thanks
    Apr 20, 2010 | Nintendo Wii Console
    Our wii is second hand and we dont know the pin code we tried sevral numbers but it didnt work so can u give us a number so we can have the internet thanks
    You should be able to format the system memory from the Wii Settings menu. It will be on the last page of settings options. It will erase EVERYTHING on the wii...channels, saves, EVERYTHING. But it will also erase security settings which should give you unrestricted access to the internet as long as your settings are correctly configured.
    I hope this helps!
    Jan 03, 2010 | Nintendo Wii Console
    Units will not stay synchronised
    Fiend your solution direct from nintendo. Here is your solution....
    http://www.nintendo.com/wiiconsole/prob676ijt65/solution
    jeonatumi4
    WII controller is working in reverse
    replace the batteries and go the the Wii options and set the sensitivity again (when it asks you if you see two blinking dots) as well as the center of the screen. Turn off the Wii (to red light, not yellow standby) and make sure you are directly in front of the TV. Repeat this process several times. (minus battery changes) and it has been working perfectly since.
    You can also "spank" your wii mote, turn it over in one hand so the battery back is up toward the ceiling, and strike it hard on top of the battery back with palm of your other hand, for some reason this has worked for many people, either causing something inside to reset or "unstick" itself.
    Jan 26, 2009 | Nintendo Wii Console
    Hand icon wont appear on the Wii main menu
    Well, mabey your sensor bar settings are out of wack. You might have your sensor bar set to above TV but you actualy have it below. To fix it, I would move the sensor bar to the opposite position, go into settings and chanage the sensor bar settings to the way you want. then put the sensor bar back where you want it.
    Dec 23, 2008 | Nintendo Wii Console
    Nintendo wii
    This may go beyond the factory settings, (completely renewed). Goto the wii options menu and click wii settings, and go all the way to the end and click format wii system memory, and read the description to make sure you want to do this and then click format if you want to restart or go back. Note: this is the only icon on wii settings menu that illuminates yellow while the others illuminate blue.
    Jun 15, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    78 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
