Question about Gaggia Titanium Espresso Machine
Gaggia Titanium stuck in energy saving mode, I cant access the menu
SOURCE:
ginko
  • 19396 Answers
SOURCE: Gaggia Titanium: stuck on 'rinse'.
Try first unplugging power cable for five minutes, see if this reset machine.
Posted on Aug 20, 2008
SOURCE: gaggia titanium is leaking water
Mine had the same problem. Take out the dreg drawer and brew unit. Then you will see a plastic cover roughly in the middle of the machine (behind where the brew unit was) that is held in place by two philips screws. Unscrew the screws and take out that small cover. It is probably filled with coffee grounds that prevent water from dripping out through a dripping hole. Clean out the grounds and you should be all set.
Gerwin Schalk Albany, NY
Posted on Aug 14, 2009
EsWorld
  • 1618 Answers
SOURCE: my Gaggia Titanium machine says ventilate
Run about an ounce of hot water from the wand.
Posted on Nov 12, 2009
  • 109 Answers
SOURCE: My gaggia titanium says it's brew unit is blocked
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
Posted on Feb 22, 2010
  • 81 Answers
SOURCE: my gaggia titanium reads"decalcify" what does it mean?
To cancel the message,press and hold the water button for 5 secs, until the message is clear. The machine is due for descaling to clean the boilers.
Posted on Mar 28, 2010
Gaggia Titanium stuck in selftest mode. How do I get it out of selftest mode?
there is a problem with the board. You have failed FUSE or Transformer.
Jan 14, 2018 | Gaggia Coffee Makers & Espresso Machines
Aug 20, 2008 | Gaggia Titanium Espresso Machine
My wife somehow changed the language to Italian and it is no longer working. It says Descalcificacion Llenar Deposito when it is not in energy saving mode. I can't follow the instuction manual to change...
Hi
You need to change your language in the menu.
Push and hold the menu button. When it changes in the window, use the up or down arrow button to move the asterisk (*) until you come to a window that has something like "lingua, or spreka", and then push the menu button again. Use the up arrow to scroll to "English". When you have the asterisk (*) in front of English, push the menu button again. You have selected English and then you can push the escape button to exit. Some machines have exit in the scroll bar, so it depends on your machine.
Apr 16, 2011 | Gaggia Titanium Espresso Machine
Titanium stuck in rinse cycle and brew unti can't be removed. Customer service is not answering the phone.
Try going into the menu and selecting rinsing. Push the enter button and use the up down arrows to chose "off". Push the enter button again to make this your selection, then the escape button. That should take it out of rinse mode.
Oct 29, 2010 | Gaggia Titanium Espresso Machine
Our machine when turned on and menu is pressed it will show energy saving press again ventilate shows. no action
Hi
When the ventilate message is showing, push the water button is you have one then open the knob on the right with a cup under the steam wand. You should get ewater from the wand. If you don't get water from the wand check for a plug in the steam tip. If you don't have a plug in the steam tip, you may have a plugged flow meter.
Dec 18, 2009 | Gaggia Titanium Espresso Machine
Power Saving mode
You can go through the menu and turn off the function.
Sep 03, 2009 | Gaggia Titanium Espresso Machine
Menu
Let the unit complete it's self test mode.
When "select product ready for use" is displayed then you press the menu button to access the menu function.
Sep 12, 2008 | Gaggia Titanium Espresso Machine
Machine won't power up after 3 days holiday!
this problem seems to be more electrical device failure as opposed to micro controller confusion. I would look for a failed power supply component, possibly an overheated resistor that has changed value and caused power loss. Look for a browned-out area on a circuit board.
Jul 13, 2007 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
415 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
