I have a Mitone flash mp4 digital player. im finding difficulty in downloading and playing files from my PC even though, as far as i know, I am downloading files provided in mp3 format. it seems that my Mitone will be playing the files downloaded but cannot be listened to. any suggestions about what am i doing wrong. maybe I still have to learn how to use it...and unfortunately the manual provided in the package isnt all that very adequate. thanks.
This may be caused by one of the following: 1. Minimum system requirements were not met. 2. Corrupted drivers. 3. Computer restrictions. 4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager 1. Right-click My Computer, and select Manage. Image 2. Click Device Manager on the left pane. Image
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes: If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
You need a professional tool like Digital Media Converter Pro.Here are the step-by-step instructions on how to use it for downloading from YouTube and converting to a file format that will play on your Sony player:
hi there, i also bought my MiTone MP4 player from Frankfurt Airport, and definitely it was the worst product i have ever purchased, from the first day i was defected, it was blinking power ON/OFF as i touch it, i had to keep it fixed beside me to keep it working, after repairing it, i found out it is not charging the battery...
Mitone MITMP25 plays only videos in MTV format, so you should use the software included to convert all videos into MTV format before you can play those. See page 21 in user manual :-)
This is done through Windows Explorer, much the same as you would delete a file on your computer. The GoGear will show up as a drive, usually "E:", and be labeled "PHILIPS".
ONCE YOU HAVE THE WIN AVI PROGRAMME THEN YOU WILL NEED THIS EXTENSION FILE (HelixSDK0715 win avi rm extention file) AND CHOOSE THE SIZE OF FILE TO SUIT YOUR SELF IN ADVANCED ONCE YOU HAVE SELECTED RM
I bought a MITONE FLASH MP4 DIGITAL PLAYER. I am downloading files from internet sites in mp3 format but am not managing to listen to them on my Mitone though it seems to be playing them. maybe i dont know how to use it yet. any suggestions please?
If a player like this http://www.szimp3.com/product_show.asp?BigClassName=MP4&SmallClassName=MP2610 , there are several clones of the Chinese goods. Firmware on the Russian here (English supports) http://ftp.roverbook.com/RoverMedia/Aria_Q7 there two different versions of firmware for the assembly player (one can work with bugs)
Methodology firmware: 1. Disable USB cable, turn off player. 2. Holding down "M" connect the USB cable. 3. The menu select 3 - y para (other then USB disk), clicking the right analog stick. 4. The system will appear logical disk 2. First at 16 mb, second - remaining FLASH memory. 5. Copy invested in this archive 5 files on 16 - MB removable disk (all except reame.txt). 6. Turn off the player through the safe extraction devices.
