Question about Maytag Neptune MAH5500B Front Load Washer
My maytag neptune sometimes fills with water and floods my floor
Twice in the past month, my washing machine has filled up with water and flooded the floor. I'm not quite sure what is going on. The machine is always off when this happens. CAN YOU HELP PLEASE!!!!!!
  • 39 Answers
Sjhtlh
It sounds like the water valve is starting to go. i would get a tech out just to make sure.
brent
Posted on Sep 29, 2008
Maytag neptune tl top load washer - the cold water continue to fill and over flood the tub.
Pull the washer 120VAC power cord. Does water continue to flow into the machine?
If yea you have a Stuck Open water valve. If know then you may have a stuck pressure switch.
Are you going to try to DIY the repair? Further troubleshooting will be required.
Apr 16, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not shut off water in rinse cycle thus flooding house. Repairman said we needed a new control panel-just want to make sure. Could it be something else? Bailey
Bailey,
Did not see this second post. If the water continues to run filling the machine try this.
Lets determine if this is a Stuck Open Water Inlet valve. If you hit the Off button does water stop flowing into the machine?
If so then I feel you have a stuck closed pressure switch never signaling that the washer has reached the proper water fill level and flooding the machine.
Are you a DIY type of owner if so I will point you to a better forum for support.....D*ick aka dh1200s
Hello, On Neptune washer serial # 34098916EF, Washer tub fills with about 2 inches of water within hours after doing a wash. When I spin the tub by hand, I hear water sloshing inside. Machine drains fine....
You have a bad water fill valve. Until you get it fixed shut water valves off at the wall so that you don't have a flood if the fill valve on the machine fails completely. Let me know if there is anything else I can Help you with.
Ken
Mar 17, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Water sometimes does not shut off. flooded twice. happens intermittently.
If when the machine is flooding if you turn off power to the machine and it continues to fill: replace water inlet valve. If flooding water stops filling when power is interupted: clean out the end of the water level switch tube where it connects to the outer wash tub.
Sep 17, 2008 | GE WHRE5260E Top Load Washer
Washer is filling up with to much water...
possible fill valve is sticking open when filling after starting washer disconnect power and listen to see if water is still running in if so replace fill valve.. if water stops possible water level switch or small hose to switch plugged ..drain washer remove screws on each side of door frame front will pull off...small hose on some models was attached to pump housing and would become plugged with lint ckd for restriction in hose from bottom to top remove screws in console to acess other end attached to pressure switch
Aug 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
The water supply to my my 2004 Maytag Neptune TL top loader will randomally not shut off, casuing the washing machine to file up to the top overflow and flood my first floor. At first it was thought that...
You have several possibles problems
The pressure switch could be faulty or the tube that runs from the pressure switch down to the accumualtor could have a cut or tear in it. solution replace hose.
or The mixing valve could be hanging open also with a piece of debris. solution replace mixing valve
For now turn the water when your not using your machine.
May 19, 2008 | Washing Machines
Mah6500 maytag is leaking
Us too are having the same problem - and recently - it has been filling with water on its own - and not emptying!!! We have had major floods!!
Jan 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Feb 05, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
355 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
