Question about Kenmore 53092 / 53094 Side by Side Refrigerator
My refrigerator/freezer isnt getting cold enough
Have a side by side Kenmore, and it is running constantly but unable to freeze anything. Also, the refrigerator side isnt as cold as it should be. I read on here the freon might be low, is this a common thing and why would it be low on freon all of a sudden? The refrigerator is about 8 1/2 yrs old and I figure that isnt very old for a refrigerator. Model # is 596.57542791 from the plate inside. Thanks so much!!
  • Anonymous Mar 07, 2009
    I had the same issue the refrigerator/freezer is working but not cooling properly.
  • Anonymous Mar 21, 2009
    You still didn't explain how to fix the problem!
    Sergeant:
    Champion:
  • 262 Answers
The problem usually isnt in the freon it usually is in the defrost system located in the freezer.I guess you have got this fixed by now and Im sorry for taking so long to get back to you but I havent used the computer in about four months because of family emerg. if you have any more problems let me know.
Posted on Nov 14, 2008
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Freezer runs constantly and food never freezes solid
no doubt the unit need a recharge of refrigerant and only a certified repairman can do it .
Aug 21, 2015 | Refrigerators
Kenmore elite freezer not cold enough, side refrigerator is warm
Hello Nelson, you will have to take it to get it fixed by a fridge serviceman or have him called out. The only other is to get a new one.
Aug 21, 2014 | Refrigerators
I have a Kenmore 26' Freestanding Dispenser Side-by-side Refrigerator, Model #596.50692000. I opened the freezer door to find melting ice and thawing food. The warmth started at the top of the...
Hi there
Sounds like bad news I'm afraid.
The freezer evaporator fan runs constantly until the freezer is at temperature.
The chiller fan only runs until the fridge is cold.
If the defrost timer is operating correctly it should only go on defrost about every 6 hours
It is more likely to be the temperature controller
You will need toget a new one.
Regards
Gordon
Apr 22, 2011 | Kenmore Refrigerators
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Jan 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore
problem has been almost certainly caused by freezer door not being completley closed allowing warm humid air into freezer, (do not say this could not happen because it often does), sollution, turn off defrost overnight, turn on following day, within 24hrs unit will work ok. Regards Adviso
Aug 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Freezer is over-freezing
most have 2 controls in the refrigerator side. 1 is a thermostat or cold control the other is a air damper. the damper allows the flow of air from the freezer to the freshfod side. if it is closed all the way you are keeping all the cold air in the freezer and that will make it colder. most cold controls monitor the air in the fresh food section and regulate the temp. and some controls are confusing and the damper actually works in the reverse of what you think. but if the unit is always running you may have a bad cold control and it is sensing the temp in the refrigerator side is not col enough, so it will continue to run until is can be satisfyed. check the control to make sure it is shutting of if you turn it up. if not I would replace it. I dont know how old the unit is but you also may have some electronics that control the temp to.
Aug 09, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
251 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
