Question about Belling XOU482 Electric Double Oven
Belling CHIM100 Cooker Hood
My Belling cooker hood halogen lights have stopped working and i need to replace them. I am unsure of how to take the lights out to replace any ideas????
SOURCE: Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Posted on Aug 01, 2008
barkencoa
  • 3463 Answers
SOURCE: Cooker is a Belling XOU270 / XOU271
You need to replace the fan oven element.
Posted on Dec 16, 2008
  • 10 Answers
SOURCE: Where can I obtain an instruction manual for a
Check fuses first. locate the model number and call manufacturer's toll free hotline.
Posted on Sep 03, 2009
SOURCE: how do i reset the clock
I need the phone# or code for my GPX tv/dvd combo. Can you help?
Posted on Oct 26, 2009
  • 3 Answers
SOURCE: Hi I can't find a manual for a Belling Format
Nope , doesnt work on me either :( dont no what i could do ::(
Posted on Feb 17, 2010
I have a belling double oven. The bottom is fan assisted. It all works okay but when it is turned off it is making a drumming noise after the fan has stopped. This lasts for at least 5 minutes. Any...
Sounds like the cooling fan bearings are worn, hence the noise after you turn the cooker off.This fan is in the top of the oven and helps to keep the inside cooker electrics cool and often keeps going for a while after you have turned the cooker off. Best to call an engineer to check this out for you!
Nov 30, 2014 | Ovens
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Apr 13, 2014 | Belling XOU482 Electric Double Oven
Free standing belling cooker model numbers
try pushing 2 buttons on left and 2nd button in from right side
push left ones first then the other! should stop it.
Could try pulling buttons out and then replacing them best is to consult a local engineer!
warmest regards
Richard The Repairman
Mar 28, 2014 | Ovens
Belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Dec 22, 2009 | Ovens
Cooker problem
If it has a timer, make sure it is set to manual or it will not heat, another possibility is a faulty thermostat, you need to find out if you are getting power to the element, if you are then element should work unless you have got a faulty one.
Plz rate this solution.
Dec 15, 2008 | Belling Ovens
Halogen ring not working
Hi .
It sounds like the temp control is faulty.
Either way you are going to have to remove the hob top to access the controls and elements, Then you can check if the element is getting a feed to it.
Sometimes you can see if the element has gone, .
If you need any further help, let me know.Good luck.
Nov 23, 2008 | Ovens
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Belling XOU482 Electric Double Oven Logo
87 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
