I have a Dimera 3500 and I can't scan any images from it. I could do so last month but no my program says that either the power isn't turned on or it's not connected to the com port. I've checked all connections and the power was on, I even uninstalled the driver and all then reinstalled and it still won't work. If anyone has any suggestions please e-mail. Any help at all would be greatly appreciated. Thank you.
YUP !! I had the same problem.......And I got lucky and corrected mine!
You either put your battery in upside down and turned the unit on OR you got the pwr. supply and the serial plug backwards.
I got lucky by 1/. inserting a NEW battery right side up and holding the pwr button until the camera flashed once. Then I removed the battery and left the camera off for a day ( or long enough to cool down the dimera CPU.) 2/. install a new battery ....That's when mine took off and operated properly. P.S. If holding down the pwr button has no results, push it on and off until you see 1 of the leds blink. GOOD LUCK !
when connected to the internet as a webcam it looks all red... How do I change the color setting?......
(More)
when connected to the internet as a webcam it looks all red... How do I change the color setting?... it is a cobra digital model dc5600
need to find a 9 pin connector that plugs into camera. i have a cable but the end for the cam is...
(More)
need to find a 9 pin connector that plugs into camera. i have a cable but the end for the cam is wrong (too small). thx!
I have an Dimera 3500 and a new computer (Vista) The connecting wire to the camera is fine but the...
(More)
I have an Dimera 3500 and a new computer (Vista) The connecting wire to the camera is fine but the computer does not have a plug for the camera. I have USBs but the wiring has pins (?). Is there some place I can get the right connections?
