Question about Air Tools & Compressors
BOSTITCH AIR POWERED NAILER - AIR LEAK THRU TRIGGER
MY N80SB-1 NAILER JUST STARTED LEAKING ( AND NOT FUNCTIONING) AFTER NOT HAVING USED IT FOR A FEW MONTHS. LEAKS THRU TRIGGER - HOW DO I REPAIR IT?
THANKS, ED
  • Anonymous Oct 06, 2008
    I have same problem
  • Anonymous Mar 27, 2014
    leaks from the back
    Problem Solver:
  • 12 Answers
Sounds like the rubber seals have dry rotted prob from not oiling it enough, but you should be able to go on the Bostitch web site and order new rubber seals for the gun
Posted on Sep 30, 2008
  • 3 Answers
Buy a new triger valve assembly or you can buy an o ring kit for trigger easy to install.
Posted on Feb 20, 2009
Air blows thru triger valve, o-rings look goods leaks so bad it does not work. where can i get new triger valve?
thanks claude
Posted on Mar 15, 2009
  • maddogweve Mar 15, 2009
    bostitch framing nailer leaks thru trigger valve, it started while i was using it. where can i find new valve??
    thanks claude
I have a n80sb have bought two tiggers and put in it av11 they both leak from the outside of the tigger what do i do
forget the out side trigger levers,you need the trigger valve assembly,its inexpensive go to your nearest bostich dealer
Dec 28, 2010 | Stanley Bostitch F21PL Nailer
BOSTITCH NAILER - LEAK THROUGH TRIGGER
Replace the trigger valve assembly (TVA).
Sep 29, 2008 | Air Tools & Compressors
I have an n80sb air is coming out around the trigger? Thanks
This is usually indicative of a defective trigger. This can be replaced. First though, try checking all the Orings. If the unit has not completed the cycle to the "ready" position, there could be an air leak. Please visit the site listed below to get a diagram of the entire unit with replacement part numbers etc. the diagram should assit you in dis-assembling the unit to clean and re-oil it.
Dan
Link: http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=CLyNls3l0KMCFeoD5QodWw4_wA
Aug 23, 2010 | Stanley Bostitch Coil Framing Nailer
I have a bostitch ridge runner that leaks air badly out of the trigger and wondering how to take out the plastic trigger in the gun. Also what would be the cause of the air leak
The air leak can be one of a few things. FIrst make sure that you have added some pneumatic oil to the air stream. This will lubricate the o-rings and make a tight seal. If that fails to resolve it, repalce the o-rings. (kits available for around $20). Next, woul dbe the trigger assembly itself. These triggers wear over time and are easily replaced.
See the website below for parts and a good diagram of the construction of the gun. You should be able to replace the parts by following the diagrams.
http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=CO6tkb2y6KICFciA5QodOlL9xg
Please note that the exactmodel number is required to get hte correct diagram.
Hope this helps,
Dan
Jul 12, 2010 | Stanley Factory Reconditioned Bostitch...
Air leaking near trigger
the purple O ring is split I would take it back or if you want to try and fix yourself let me know and I will help
Sep 30, 2009 | Stanley Factory Reconditioned Bostitch...
Constant air leak
Sounds like you need a repair kit or take to a tool company that installs the kit.
Jun 09, 2009 | Stanley Bostitch Coil Framing Nailer
Stanley Framing Nailer Leaking Air Around Trigger
Your tva11 valve can be repaired easily if you have a source for orings. I purchase orings from several companies including lowes (in plumbing dept sold in 10 pack for about dollar), www.grainger.com (oring kit metric, cost about $10) harbor freight (oring kit about $5), also orings are sold by size at bearing companies. I have repaired many of these valves by just cleaning debris and lubing with silicone paste (sold at lowes in plumbing dept used for lubing faucet orings). To attempt repair of valve, remove nails, remove roll pin that holds trigger (3mm) to expose tva11 valve. Mark position of valve in body of gun because the retaining pins fit thru an indention in the valve. Next remove roll pin/s that hold tva11 valve, they are just above the valve in the body of the gun(3mm x 30mm). You will need to apply air pressure to gun to remove the valve, however use heavy glove to catch valve because it can come out with force. (try lowering air pressure to gun for this procedure. With valve in hand, use marker to mark position of inner part in relation to outer, remove the two pins that hold valve together. Push out the inner cylinder and look at the middle oring(usually the problem, could be loose or cut) , If cut or loose replace and lube with silicone paste and re-assemble. Check outer orings for nicks, replace as necessary (usually good). Clean valve port, lube port, then re-install valve into gun and insert temporary retaining pin and test for leak. You should be good to go. Good luck and email if you have questions.
Mar 30, 2009 | Air Tools & Compressors
N80sb-1 stanley bostitch framing gun.
Yes your nailer will drive other sizes of nails. For info and parts go to www.bostitch.com and look for the support tab then select service parts. Here you will find parts list and manual. To remove the tva11 trigger valve remove the retainer pin (the pin is 3mm) for the trigger and remove trigger. Next remove roll pin/pins that retain trigger valve. Use heavy glove to catch trigger valve as you apply air pressure to gun. The valve could pop out with great force so try lowering the pressure to gun. Before installing the new valve, check the opening for sharp edges which will cut orings. Good Luck and email if you have more questions.
Mar 14, 2009 | Stanley Air Tools & Compressors
LEAKING BOSTITCH AIR NAILER
you probably have a trigger valve that is green. if so then it will have to be replaced, the valve runs about $ 20 but you can put it in your self.
Dec 26, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
2,928 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
james allen
james allen
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
