Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Door sag on Bosch 500 plus washer
We have had our 500 plus series washer and dryer for about 6 months now. I just noticed today when I went to do a load that the door wasn't closing properly. After further inspection I found the door wasn't lining up with the latch. If I lift it up a bit it goes right in and closes. I looked at the dryer door also and it to looks like its starting to sag a bit. Its showing signs of rubbing on the top. Does the door hinge have adjustments?
2 Suggested Answers
  • 183 Answers
SOURCE: Bosch 500 series Front Load Washer Door hanging a bit lower than when purchased
Even if you do not realise it most people lean on the door as they open it, to rectify with the door open but almost in the closed position lift the door by pulling up on the door catch end, this will straiten the hinge, very common problem Regards Engineer
Posted on Jul 30, 2007
Bosch 500 series front load washer less than 6 months old. Getting code E27 when turning it on... suggestions before I call service?
E27 means there is a problem with the door lock.
Unplug the machine for 30 minutes and try again. If the error code returns you will need to replace the door lock assembly. Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Replace the door lock assembly on the washer. Refer to your washer manual for the correct part numbers.
Check to see if your Bosch washer is still covered under warranty. If so, you could receive free replacement parts and service for the faulty door locks.
Hope this helps (remember to rate and comment this answerr).
Jul 16, 2011 | Bosch Evolution 500 Series B20CS51SNW 20.2...
Is it possible to reverse the doors on a Bosch Nexxt 500 series dryer? If yes, does it require a kit from Bosch?
yes ,it is possible,you don't require a kit from bosch,however,you will need to disassemble the machine.if you are not confident,get someone who is.
Oct 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Lint filter not allowing dryer door to unlock
Try unplugging it for an hour.. Might reset it..
Hope this helps !!
Rate me good ;o)
Jul 13, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
How do you clean the drain in a bosch next 800 series washer?
Almost all Bosch machines have a manual drain trap that usually can be accessed from a small door in the front panel. Open the door and you will see the trap access.
Jun 05, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Jul 26, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
