Question about Air Tools & Compressors
BOSTITCH NAILER - LEAK THROUGH TRIGGER
I JUST STARTED A DECK PROJECT AFTER NOT USING MY NAILER FOR A FEW MONTHS. IT STARTED LEAKING AIR THROUGH THE TRIGGER AREA AND DI NOT FUNCTION. THE LAST TIME I USED IT - IT FUNCTIONED WELL. HOW DO I FIX IT AND WHERE DO I GET THE PARTS. THANKS, ED
    Guru:
  • 859 Answers
Please do not rate this until we've finished our dialog. Okay?
Do you see an oil port or small hole in and around the trigger?
The trigger that you use to actuate the gun operates a plunger diverting air from a the storage chamber into the barrel. This plunger usually has a least one and usually two o-rings. If there is an oil port or small hole on the body above the trigger and either forward or to the rear of the trigger, this may lubricate the plunger enough to revitalize the o-rings and create air from the storage chamber escaping at the trigger.
O-rings do shrink in a drier climate should you be in one. They also shrink over time. Lastly, you may have one with a tear in it and this could also cause the leak.
As I seem to recall Bostitch is one of those companies that encourages their equipment be returned to a factory service center. And air guns being somewhat dangerous this would normally be the case.
Can you supply the model version and perhaps I can also provide you with a parts explosion that will show you the elements to access should you desire to undertake the replacement of the o-rings yourself.
Regards,
Worldvet
Posted on Sep 29, 2008
  • 171 Answers
Replace the trigger valve assembly (TVA).
  • 1 more comment
  • Todd Gale
    Todd Gale Sep 29, 2008
    If you go to the link below you can select your model number and you will see the parts list and instructions for the repair. It is not that difficult. If you provide me with the model number, I will get you the information.
    http://bostitch.com/default.asp?TYPE=STA...
  • Todd Gale
    Worldvet, please do not answer questions you are not qualified to answer. This is a dangerous repair if not handled properly and your answer about replacing an o-ring is not correct and could cause this person to suffer injuries. Stanley/Bostitch makes their repair procedures available to the enduser and does not require any such repair policy. I would appreciate you not answering posts you are not qualified to just for the sake of making a few dollars. I will report your actions in the future.
  • Todd Gale
    Todd Gale Oct 03, 2008
    Please rate this solution.
Internal air leak won't pressure up
Sounds like the trigger valve is bad. If the air is leaking out of the trigger you can buy a kit and replace it. Try eReplacementParts com or your local Bostitch service store. It's really simple to change, check out this site for step by step, How To Replace The Trigger Valve On Bostich Nail Gun How To Guides DIY... OEM Replacement Parts DIY Repair
Mar 17, 2014 | Stanley Bostitch SB1850BN 18Gauge Brad...
I have a Bostitch N88RH stick nailer with contact trip. For some time, when I connected the nailer (without actuating the trigger or tip), it would fire a nail. Now, it will often fire a nail when first...
Usually, if you change the trigger valve (TVA11) the nailer will function as before. This problem could be also be caused by air leaking past the orings in the headvalve (3 orings). Easy to check. Remove the head and pull out the headvalve (white plastic piston). Look carefully at the cylinder where headvalve orings make contact and look for smooth surface. If scratched or deep groove, replace head or try to smooth out with fine sandpaper. You can make the orings fit more snuggly against the cylinder by using one or two turns of Teflon tape under the oring (just the outside orings). Apply white grease and replace head to test.
As for the trigger valve, remove the trigger to expose the valve. Check if the trigger pin moves from side to side or seems loose. If it seems loose replace the valve. If the valve has a metal pin (many have plastic (metal better)), you can pop out the valve and just replace the orings on the inner plunger. If plastic pin replace the valve. To remove the valve, remove the roll pins in the body of the gun (3mm) and apply air pressure to the gun. Use lower pressure than normal and use a glove or bunched up shop rag to catch the valve as it is pushed out by the air. Could come out with force depending on the pressure. Note the slots on the valve as they relate to the roll pins so you can reinstall correctly. Good luck.
Sep 01, 2013 | Stanley Air Tools & Compressors
Air is leaking from somewhere around the trigger and the nailer will not fire...the gun is only about 3 months old
I would take it back for warranty repair if it is that new. If not I have detailed instructions on how to remove the trigger valve assembly from the tool. If it is leaking air it is probably a split o ring on the valve.
Jun 02, 2011 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
I have a bostitch ridge runner that leaks air badly out of the trigger and wondering how to take out the plastic trigger in the gun. Also what would be the cause of the air leak
The air leak can be one of a few things. FIrst make sure that you have added some pneumatic oil to the air stream. This will lubricate the o-rings and make a tight seal. If that fails to resolve it, repalce the o-rings. (kits available for around $20). Next, woul dbe the trigger assembly itself. These triggers wear over time and are easily replaced.
See the website below for parts and a good diagram of the construction of the gun. You should be able to replace the parts by following the diagrams.
http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=CO6tkb2y6KICFciA5QodOlL9xg
Please note that the exactmodel number is required to get hte correct diagram.
Hope this helps,
Dan
Jul 12, 2010 | Stanley Factory Reconditioned Bostitch...
Leaking air when trigger is depressed
This is an indication of a defective seal. Try adding a little pneumatic oil to the gun and triggering it a few times. Sometimes all it is is a small leak in the o-ring because of a lack of lubrication. If not, then try replacing the o-rings (kit available for around $20). The next possibility is the trigger itself. I have replaced the trigger assembly on mine once thus far.
Good luck,
Dan
Jul 06, 2010 | Stanley Bostitch FN16250K - 2 16 - Gauge...
What causes air leak around trigger and loss of compression on bostitch on n79ww modelframing nailer
Are you using air tool oil fairly frequently? Any rubber "O" rings will wear rapidly if not lubricated properly.
Jan 01, 2010 | Stanley Bostitch N88rh Framing Nailer...
Air leaking near trigger
the purple O ring is split I would take it back or if you want to try and fix yourself let me know and I will help
Sep 30, 2009 | Stanley Factory Reconditioned Bostitch...
Stanley finsish nailer and air is leaking through the trigger as.
If the air is coming out the trigger it must be replaced. Depending on the model of gun you will have to replace the trigger assembly or various o-Rings. Find a Bostitch dealer in your area and they will supply the parts you require.
Jul 14, 2009 | Stanley Bostitch FN16250K - 2 16 - Gauge...
Constant air leak
Sounds like you need a repair kit or take to a tool company that installs the kit.
Jun 09, 2009 | Stanley Bostitch Coil Framing Nailer
BOSTITCH AIR POWERED NAILER - AIR LEAK THRU TRIGGER
sounds like the rubber seals have dry rotted prob from not oiling it enough, but you should be able to go on the Bostitch web site and order new rubber seals for the gun
Sep 29, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
588 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
