Question about Microwave Ovens
Control panel display indicator lcds are only half showing and are dificult to read...is there a replacement lcd panel for a sharp carousel microwave R-340E...thanks
  • Anonymous Sep 30, 2008
    I have R-330AW model Sharp Microwave oven LCD Display shows only Character C where Can I buy replacement unit (control panel)
MicrowaveSvc
  • 9098 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
  • 338 Answers
SOURCE: Sharp microwave oven LCD display malfunctions
you medd whats called a smart board. these go out a descent amount you can get and in stall the board yourself for maye around $100
Posted on Nov 30, 2008
  • 38 Answers
SOURCE: Hi our Sahrp Carousel microwave LCD panle display is not working
You have to replace the control board. Sharp has had problems with the display boards for awhile. There is no bulb or fuse you can change.
Posted on Mar 15, 2009
fieldy14
  • 456 Answers
SOURCE: Looking for instruction manual Sharp \carousel
if you google the model number and the brand you should be listed with a series of sites that supply manuals, service manuals, etc.
Posted on Aug 16, 2009
mcdevito75
  • 1970 Answers
SOURCE: User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
Posted on Jul 07, 2010
Model R1800 Sharp Microwave Looking for Sharp Carousel Convection Oven Control Panel Model R-1800
What are your sympotms? I repair those boards.
Feel free to contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 22, 2016 | Sharp Microwave Ovens
Touch screen panel not working. in past unplugged and then plugged in again and it worked but now nothing
If you mean the display (the microwave works but no info on display) look here for a good diy thread:
http://nzlamb.wordpress.com/2010/04/10/sharp-carousel-microwave-lcd-repair/
Aug 12, 2011 | Sharp R-1750 Microwave Oven
I HAVE A SHARP 1500 MICROWAVE OVEN THE LCD READ OUT STOPPED ABOUT 4 MONTHS AGO I THINK THEY SHOULD REPLACE OR RECALL
This can usually be repaired for $39.95 nationwide. We have good results with these.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Sep 02, 2010 | Sharp R-1501 Microwave Oven
Sharp Carousel 2 Microwave start switch broken
Hi George,
I ahve the same issue. Did you manage to repair it or did you need replacement?
If repaired then how?
if replaced then where did you manage to get the part from?
Regards
Vipin
Jun 04, 2009 | Sharp R-1870 Convection/Microwave Oven
Control Panel for Sharp Carousel Microwave Oven
would you help me to find..
driver Acer Nplify 802.11b/g/Draft-N WLAN
May 07, 2009 | Sharp Microwave Ovens
Mar 15, 2009 | Sharp Microwave Ovens
Sharp carousel R1754 microwave...display screen keeps scrambling
Stay away from Microwavedisplay.com and William E Miller. He will take your money and will not return your display unit let alone repairing it. Do your research. There are a lot of us out there!!!
Dec 27, 2008 | Sharp R-1750 Microwave Oven
Some of the lcds on the lcd display are not working on a sharp carousel R-490C(s) model microwave. Can they be repaired/replaced and is it economic?
We repair these for customers nationwide here in the US with our guaranteed $39.95 service.
I'm guessing you're in Australia?
We repair a few of these for Australian, UK, and Canadian customers, but the extra shipping is a factor in the choice to do so.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa.
I'm confident this will be a FixYa! We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Aug 10, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
148 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
